04-06 Ralliart Engine/Drivetrain (no forced induction)
Engine Knock
Old Sep 21, 2010 | 09:08 PM
Raikiri's Avatar
Engine Knock
So unfortunately over this weekend I would have to say that the mentality that my RA is invincible is completely gone lol
On the way to MOD when driving a little spiritedly my engine started knocking and we just ripped apart the oilpan to do a general diagnosis and this is what we found
i dont know if you can see it but the oil is shiny at the bottom. yeah thats metal flakes from...
THESE 2!
From the looks of it I spun a rod bearing and well now my crank and rod is toast... anyone have any spare parts to give(hopefully? yes? lol) or sell just let me know
Luckily not too much damage was caused since we caught it early from what we think but I guess this is what you need to replace when it breaks
Crank
Rod/Main Bearings
Gaskets
and Rod and Rings
but thats just the general in hopes if nothing else broke. again if anyone has a crank/rod they would like to sell hit me up! =]
Definitely would love to thank the guys from Douglas Automotive down here for helping me get the car off the road when I broke down on the highway. Good set of guys hopefully who can build me a custom turbo when i finish repairing and have money?
Old Sep 22, 2010 | 04:21 AM
lanzerralliart's Avatar
EvoM Super Moderator
Man that suck hopefully it all works out for you from here..... keep us posted and maybe try talking to LSD has like 3 motors, just a thought.
Old Sep 22, 2010 | 04:42 AM
meckert's Avatar
Pull the crank and have it machined and save yourself some cash.
Old Sep 22, 2010 | 06:01 AM
Jabl3s's Avatar
that was a crazy moment man... one minute all 10+ of us are cruising happily, the next minute i see you pull over fearing the worst and seeing all us pull over as well. I'm glad it is not as bad as it could have been. And I'm glad you found someone to help you get your car back home. Hope you get it all fixed soon.
Old Sep 22, 2010 | 06:15 AM
Raikiri's Avatar
from the looks of it i think i scored the crank enough where it should be toast? do you think machining it will be able to fix that? im trying to look into as many options as possible to save some cash
Old Sep 22, 2010 | 07:26 AM
Ralliart_on_LSD's Avatar
PM sent
Old Sep 26, 2010 | 09:19 AM
xmaster19's Avatar
What kind of mods you had done on your car? Running any boost? Or bone stock?? Man that sucks, I hope mine doesn't do that as well!
Old Sep 26, 2010 | 01:06 PM
Resurrected RA's Avatar
I think I will see the same thing, once I get a chance to pull my engine apart. Keep us posted on your fix.
Old Sep 26, 2010 | 02:49 PM
Raikiri's Avatar
does anyone know if i can source a crankshaft from other engines? been searching yards and most dont have the 4g69 engine so just wanted to know if others will work
mods are as said in my sig. no boost
we believe my oil pump may have failed? not sure exactly what happened as havent looked into it. most of my concern has been getting the car running
Old Sep 26, 2010 | 03:16 PM
That's a little odd that you can't find a motor. The 4g69 is in galants,lancers,eclipses, and outlanders. Did you try car-parts.com?
Old Sep 26, 2010 | 03:26 PM
Raikiri's Avatar
is the crankshaft 6 or 7 bolt?
i searched car-parts.com and nothing really comes up for eclipse/lancer/galant/outlander. im assuming i should be searching for the 2004-2006 years?
EDIT: fixed from camshaft to crankshaft
Old Sep 26, 2010 | 03:37 PM
GearDownSon's Avatar
Man
I dont see how i missed this thread. Sorry to hear about it bud. You are one of the very few people that ive heard having engine failure.
As for the years you are correct. You should have all kinds of hits...
Old Sep 26, 2010 | 03:43 PM
Raikiri's Avatar
one of my mechanics believe that all the bottom ends of the 2.4 engines should be the same? so all he needs to know is if its a 6 or 7 bolt to the flywheel
Old Sep 26, 2010 | 03:58 PM
7 Bolts
You are talking about the flywheel right? You asked about the cam earlier..
Old Sep 26, 2010 | 04:01 PM
Raikiri's Avatar
i apologize. i meant crankshaft. i was wondering why i got no results. however i got results but the years dont match =/
is it an accurate assumption though that the bottom ends are all the same in the 2.4 engines? its just the heads that are different in the blocks
