04-06 Ralliart Engine/Drivetrain (no forced induction)
TB Swap
Old May 4, 2011 | 12:22 PM
  #91
Raikiri's Avatar
yeah im interested in the video too. i have a full bolt on setup but still not hearing it as profoundly as you guys say it is
Old May 4, 2011 | 05:29 PM
  #92
lanzerralliart's Avatar
EvoM Super Moderator
I've tried before but with my iPhone and the window down you only hear the wind moving
human ears > iPhone
Old May 9, 2011 | 07:17 PM
  #93
$MIVEC$'s Avatar
I just did the TB swap today and the change is very...VERY noticeable. The whistling noise can be heard through all gears when pressing the throttle(Depending on the throttle you give).
The car revs differently:
-revs slightly faster
-the CAI has a much more meaner sound
-"whistling" starts near the 2600rpm depending on the gear.
I also installed the UDP again after trying out the new TB. I had forgot how it felt to go WOT on the first two gears with the UDP. Right now im very pleased with the 63mm TB.
I will be installing a cam gear soon and will probably do some dyno runs. Maybe I can switch TB's while doing some runs and check for the slight change and then set the cam gear.
Old May 9, 2011 | 08:57 PM
  #94
lancerralli06's Avatar
how does the UDP feel with the TB? I still have to put my UDP on lol.
Old May 9, 2011 | 09:09 PM
  #95
Raikiri's Avatar
wish i knew what it felt like to change gears and notice any differences. downfall of autos...
Old May 10, 2011 | 08:22 AM
  #96
$MIVEC$'s Avatar
Well the UDP helps rev quicker and the throttle response is much better. I had changed the clutch to an ACT 50/50 and now after the UDP and TB the car goes nuts on 1-2 gear change the dash board just feels like its going to break because of the wheel hop
Old May 10, 2011 | 10:25 AM
  #97
Then now it's time to invest in some devcon flexane and a weekend of down time to make some solid motor mounts
Old May 10, 2011 | 11:16 AM
  #98
Raikiri's Avatar
or buy roblaza's blox mount
Old May 10, 2011 | 11:33 AM
  #99
Yeah the front will help but the rear is always the one that fails.
Old May 10, 2011 | 03:02 PM
  #100
$MIVEC$'s Avatar
I have a BLOX motor mount coming this way as we speak
Old May 15, 2011 | 02:19 PM
  #101
nerdbotSKRA's Avatar
I just installed my TB upgrade, installed with the battery disconnected, let the car idle for 10-15min and took it for a spin. When I clutch out (neutral) at a stop sign or a red light, the revs move their way up to 1500 or so and then simmer. When it's parked it idles normal.
Anyone know why?
Is this going to eventually learn itself away or do I have to re-reset something ?
Old May 15, 2011 | 02:37 PM
  #102
Tw3NTy0n3's Avatar
Anyone know why?
Same happened to mine for a while. Eventually it learned and went away.
Old May 15, 2011 | 03:05 PM
  #103
That's good, I was wondering cause I don't want it doing this when I get my exhaust lol. Second spin the revs were hanging around 1100. Hopefully it dies down (mine is currently a 60mm bored to a 65, polished on both the manifold side and air intake side, was supposed to have a 63mm but USPS lost it..)
edit: car figured itself out, revving at about 900 at idle now once off the gas, will need to take it for a few more drives. Better low end, throttle response, definitely a change in throttle tone (growls more), I like it!
Old May 15, 2011 | 04:00 PM
  #104
mmoulton470's Avatar
I still need to do this for my trans mount.. Does anyone know of a place that sells Devcon flexane in the states?? I've looked and I can only find it online in bulk.
Old May 15, 2011 | 10:40 PM
  #105
There's places I want to say harbor freight but i can't remember off the to of my head
