04-06 Ralliart Engine/Drivetrain (no forced induction)
P2195
Old Oct 17, 2010 | 08:29 PM
Darewood's Avatar
P2195
So did the TB swap today, I also added in my thermal gasket too. But I have a SES light. The code was the P2195-Stuck on Lean. I want to say it said B1S1 also. So is this something to do with the TB? Or maybe the spacer? And how bad is to run lean?
Old Oct 18, 2010 | 03:17 AM
Ralliartize It's Avatar
The order I did was IM then thermal gasket, then OEM gasket, then TB. No leaks at all.
Old Feb 14, 2012 | 03:28 PM
adio214's Avatar
make sure youre intercooler piping is tight and that your using t-clamps, cause i had the same problem, and it looked like they were tight but they needed a little extra umph. i had the same code and said it was to lean and so far the cel hasnt come back...try vacuum leaks and your o2 sensor, prolly the upstream one
Old Feb 14, 2012 | 07:50 PM
Raikiri's Avatar
first: we dont have turbos stock
second: this thread was left alone over a year ago. he probably has fixed the problem by now or else they would've continued posting in this thread
dsmchiz
Apr 16, 2016 03:08 PM
06 ralli///art
Sep 7, 2014 11:05 AM
JohnRoland
Feb 14, 2012 03:19 PM
reconracer
14
Jan 16, 2011 12:55 AM
OneEyedJack
47
Sep 9, 2010 07:30 AM
