04-06 Ralliart Engine/Drivetrain (no forced induction)
Timing belt/UDP
Old Jan 14, 2011 | 07:52 AM
  #31
Thomar's Avatar
regarding the timing mark, im pretty sure the RRM pulley has a little hole drilled into it that will fit onto the crank. the OEM pulley had something similar... its been a while since i replaced it now, memory is fading.
Old Jan 14, 2011 | 09:22 AM
  #32
lancerralli06's Avatar
Yeah, I saw the small hole between 2 of the bolt holes, so there is really no need to make a mark on anything?Or am I mistaken?
Old Jan 14, 2011 | 09:41 AM
  #33
Raikiri's Avatar
I don't really see how it makes a difference on timing as that's what the timing belt is for...
Old Jan 14, 2011 | 10:26 AM
  #34
otter's Avatar
EvoM Administrator
Timing is marked on the crankshaft's timing gear so it really doesn't matter whether or not it's marked on the UDP. If for some reason you need to know where TDC is with the UDP on the car (such as when adjusting valves), put the keyhole at 3 o'clock.
Old Jan 14, 2011 | 10:30 AM
  #35
veloracer's Avatar
Really, all you need to know is right here Pulley installation
My one bit of advice for you is to set aside a good hour and make sure not to rush. BEFORE you take anything off, open the hood and review the mechanics of the belt side of the engine. Look at the belt and how it is on. Feel around so you know what you are dealing with. It's not necessary to take the wheel off, but I'd suggest to pull the wheel off and really look how it is all set up prior to removing anything. This will help you get acquainted with that side of the engine and what you are going to be tackling.
I'd also suggest to buy a subscription to AllDataDiy for the R\A. It's worth it's weight in gold.
have fun and enjoy the rewards.
Old Jan 14, 2011 | 10:47 AM
  #36
Raikiri's Avatar
The bottom of this thread i made earlier has some pictures that help w/ installation thanks to tw3ntyon3
https://www.evolutionm.net/forums/04...ve-pulley.html
This image pulled off the RRM site has how the belt should be run though the pulleys
SORRY if its a little big. It is not my picture I pulled it directly off RRMs install webpage
Old Jan 14, 2011 | 12:45 PM
  #37
I've read pretty much every thread about Underdrive pulleys the other day for about 5 hours, but the only thing that was concerning me was accidentally rotating the crank out of proper timing.
Old Jan 14, 2011 | 12:54 PM
  #38
veloracer's Avatar
has no referrence to timing so you are good to goooooah! Install, start car, drive like you stole it. lol
Old Jan 14, 2011 | 12:58 PM
  #39
So if the crankshaft spins at all when removing bolts or anything it doesn't matter? Sorry for all the questions, I just like to be thorough.
Old Jan 14, 2011 | 01:06 PM
  #40
Raikiri's Avatar
it doesnt matter.. the crank is still connected to the vales via the timing belt...
Old Jan 14, 2011 | 07:59 PM
  #41
otter's Avatar
EvoM Administrator
It actually does matter. Turning the crankshaft clockwise is fine, turning it counterclockwise is not. Turning it counterclockwise risks compressing the timing tensioner and ultimately causing the timing to skip a tooth.
Superchargedk20
Sep 9, 2016 09:55 PM
EvolutionRacing
Jun 1, 2016 07:12 PM
formerSTIowner
Mar 23, 2016 03:40 PM
EvolutionRacing
Jan 11, 2016 12:35 AM
GranMassaX
18
Mar 28, 2005 08:46 AM
