04-06 Ralliart Engine/Drivetrain (no forced induction)
Spongey peddal after clutch swap
Old Sep 16, 2011 | 04:59 PM
roblaza's Avatar
So I bled the clutch again today and adjusted my pedal from inside the car... It helps a little bit, but it's still pretty soft.
Old Sep 16, 2011 | 06:16 PM
CrAnSwIcK's Avatar
keep on bleeding...if it gets better with bleeding, keep bleeding..
Old Sep 16, 2011 | 06:24 PM
roblaza's Avatar
I bled for a good 20 mins and didn't get one bubble at all out of there....
Old Sep 16, 2011 | 07:36 PM
GearDownSon's Avatar
Originally Posted by otter
How did you bleed the clutch? People often bleed it incorrectly as you do not bleed the clutch the same way you'd bleed brakes.
This...seriously
Old Sep 16, 2011 | 07:58 PM
roblaza's Avatar
Had someone in the car, depress the clutch pedal and hold, open bleeder valve, close bleeder, off pedal. Repeat over and over. There was absolutely no pumping as you would with the brakes.
Old Sep 16, 2011 | 08:14 PM
CrAnSwIcK's Avatar
when my system was empty, after my rebuild, i had to bleed brakes and clutch for like 2 hours, and put 3L of fluid through before i got ample pressure..
Moore Auto
EvoX 'For Sale' Engine Internals and Drivetrain
Mar 11, 2015 08:53 AM
WickedIXMR
70
Jan 25, 2012 05:30 PM
ch53avitech
10
Dec 8, 2008 02:17 PM
hanahawaiian
Northwest Region
Apr 24, 2008 08:04 PM
vassago
13
Mar 16, 2006 04:39 PM
