04-06 Ralliart Engine/Drivetrain (no forced induction)
Engine Stalling, CEL and code p1020
Old Feb 1, 2013 | 01:57 PM
jparz087's Avatar
All this started happening after I installed my new battery.
Start the car up and it'll stall out as I slow down and stop. Once the car warms up it doesn't stall out, but I can tell its fighting.
Anything I can check before bringing it to the dealer? Thanks.
Old Feb 1, 2013 | 03:24 PM
RallyartRob's Avatar
Check spark plugs, i think i remember someone saying thats related to lean, or missfire. If u have a cold air intake check the filter and the MAF if the wet then thats your problem.
If u search there was a list in a thread somewhere that has all the codes and what they mean
https://www.evolutionm.net/forums/04...ar-normal.html
says its a mivec problem have you done timing or oil change?
Old Feb 1, 2013 | 05:51 PM
jparz087's Avatar
Spark plugs were done at 80k ( at 100k now ) timing belt was done 40k miles ago and only been 2000 miles since my last oil change. No cold air intake or any mods.. the CEL turned off by itself but car is still stalling...
Old Feb 19, 2013 | 02:53 PM
xmaster19's Avatar
Any problems starting the car after a refuel?
Old Feb 19, 2013 | 03:39 PM
Tsensational's Avatar
Check wires. Specifically, that MIVEC oil pressure switch and things it connects to. Moving things around may have messed with it a tiny bit but its an easy thing to check.
Old Feb 19, 2013 | 09:04 PM
CrAnSwIcK's Avatar
make sure you clean your battery posts and terminals and that they are tight...momentary loss of power will throw all sorts of weird codes.
that is weird that it's throwing a MIVEC code and then stalling...
Old Feb 20, 2013 | 04:55 AM
2006_RA's Avatar
Since it happened after installing a new battery I would revisit that installation seeking loose connections.
Old Feb 22, 2013 | 08:41 AM
rzrxn's Avatar
or maybe you got a bad battery? i'm not sure about this but maybe try to exchange your battery and get a new one and tell them that your car isn't holding a good idle since you switched batteries. i'm sure they can work something out if you ask nicely
khay silk
Dec 5, 2015 11:21 PM
MarkChamorro
Jun 12, 2013 10:08 PM
josephcastelar
Apr 22, 2013 11:37 AM
Nelson999
Jun 19, 2012 08:28 AM
chickenbrest
Jan 24, 2006 06:26 PM
