04-06 Ralliart Engine/Drivetrain (no forced induction)
New oil pan, problems
Old Aug 19, 2015 | 12:52 PM
Ralli_Red's Avatar
Im wondering if anyone Here ever Run into the problem I'm having I've replace the oil pan twice I've used that black gasket sealant I've use over 4 gaskets dropped the pan over 5 time cleaned it really good I mean cleaned it hella good and it leaks in the same spot right next to the flywheel towards the back part . Idk what else to do . My car recently started jerking really hard in 1st year maybe that oil in getting in there ? Idk someone please help me out
Old Aug 19, 2015 | 01:55 PM
bakuro117's Avatar
Are you sure the oil is leaking from the oil pan? Have you removed the cover on the bottom of the transmission that closes of the bell housing to see if anything is leaking from there?
Old Aug 19, 2015 | 02:19 PM
Ralli_Red's Avatar
It's leaking right from the top rear corner where the cover goes on the flywheel it's coming from gasket . I notice there's a line like that connects from the flywheel to where the pan bolts up I was seeing if that nut is loose but it's tight I wish I could show a pic every time I try to post a pic on here some random guy pops up with a black lancer
Old Aug 19, 2015 | 04:04 PM
CrAnSwIcK's Avatar
check your rear main seal...
Old Aug 19, 2015 | 07:41 PM
Ralli_Red's Avatar
Will oil leak out the gasket of the oil pan of the main seal is broken ? And also any idea why the car jerks in 1st gear
Old Aug 19, 2015 | 09:19 PM
bakuro117's Avatar
You can see the rear of the crank shaft here in the bottom right. Where the flywheel connects, if that seal around the shaft goes bad it could appear to be coming from the oil pan.
Old Aug 19, 2015 | 09:45 PM
Ralli_Red's Avatar
I'm doing my clutch soon so do I have to take out the whole tranny to get to it ? And wouldn't it have to get past the oil pan gasket ? Or is there another way it could get out ?
Old Aug 20, 2015 | 01:58 AM
CrAnSwIcK's Avatar
car jerking in first is probably your clutch...yes the transmission needs to come off to replace the clutch.
not sure what you're asking, in the above question
Old Aug 20, 2015 | 06:08 AM
Ralli_Red's Avatar
No to get to the main seal ?
Old Aug 20, 2015 | 06:53 AM
Ralli_Red's Avatar
If the rear main seal is leaking from where does it leak out ? Thats what I'm asking doesn't it have to go through the oil pan gasket
Old Aug 20, 2015 | 07:15 AM
2006_RA's Avatar
No, it leaks from between the crankshaft and the seal, or the block and the seal. It will run down and could appear to be the oil pan gasket.
Old Aug 20, 2015 | 09:29 AM
CrAnSwIcK's Avatar
Yes, the oil pan touches the rear main seal housing...so if it was leaking between the block and the housing, then it would look like the oil pan was leaking...this is what the rear of the block looks like with no transmission/flywheel/clutch...
Old Aug 20, 2015 | 07:32 PM
Ralli_Red's Avatar
Ok so just wait till I remove the tranny to get to it huh
Old Aug 20, 2015 | 07:57 PM
CrAnSwIcK's Avatar
yes, I replaced my rear main not too long ago, it's pretty easy.
redlinedrift
28
Nov 11, 2011 03:16 PM
er0e
Apr 26, 2011 10:10 PM
downshift411
May 30, 2008 09:54 AM
