Ralliart pet peeves?
Originally Posted by matthinchey
I LOVE MY RALLIART.
But some things that could make it even better are:
1) A sixth gear. I'm driving 110 Km/hr and I am sitting in mid 3 grand RPM's. Just a lil hard on the fuel consumption.
2) A trunk that opens with a push of a button would be nice.
3) A first gear that is a lil smoother. Whatever though, just makes me need to work the clutch a little smoother.
4) More interior lighting, MAN this thing is dark.
5) Larger exhaust tip. No, I don't want a big can on the back, but I will be upgrading the muffler soley because the rear tip doesn't fill out the opening in the bumper.
6) A CD player that doesn't crap out with extended use in hot weather. I was doing a road trip and after 3 hours in 20 Celsius it wouldn't read the CD.
Other than that this thing is awesome. Best Bang for the buck. Never once have I regretted the purchase.
Thing ended up screwing up my cds... oh well.. Guess its gotta go in place of an MP3/CD Player
I LOVE MY RALLIART.
1) You're quite right... I want that too!
2) Yeah, well when I asked about that the salesman said the car had it! Only when I drove off with it did I notice the button was not on the remote!
5) No need to change the muffler just to get a bigger tip, do as Deltarider99 and I did and get a tip welded on. 25$ for a very high quality double-walled stainless tip (and around 20$ for the welding).
6) Get them to fix it... it's under warranty and it should work correctly or they swap it.
Just got a new cd player under warranty for similar problems.... and yeah for the exhaust, yall are probably gonna flame away, but I just put a cheap $10 tip from walmart on, so far no problem, and looks just fine.....
didnt know if it would hold or anything though.
Originally Posted by aflancerdude
I was gonna do that..
Originally Posted by Azure
Mine was a simple bolt on...held no problems up to now...just be sure to check it every now and again.
I might actually look at that for a temp solution til I get the axle back exhaust.
yup... three bolts spaced around the tip.... you cant even tell unless you actually lay underneath the car... and yes it is just a temp til I get an exhaust...
