02 sensor
Old Aug 6, 2006 | 09:22 PM
RalliArtChink's Avatar
02 sensor
Hey guys, which of these is the correct one to replace the oxygen sensor, after the catalyst, where the mechanical fix goes into?
www.autowareshouse.com
Any other sites have it cheaper..?
Old Aug 7, 2006 | 06:28 AM
Myszkewicz's Avatar
#BS15590 Oxygen Sensor Bosch $308.20
Vehicle:
2004 – 2004 Mitsubishi Lancer
Fits Engine – Chassis:
2.4L, 4 Cylinder, GAS, FI — Sportback
OE TYPE OXYGEN SENSOR - AFTER Catalyst, Original Equipment Replacement
Or, if you have the skills and tools to put the connector on it:
#USOS-4000 Oxygen Sensor Replacement $42.72
Vehicle:
2002 – 2006 Mitsubishi Lancer
2.0L, 4 Cylinder — Lancer
2.4L, 4 Cylinder — Lancer
OXYGEN SENSOR -- Oxygen Sensor. Univeral Type, 4 Wire 20cm Long, w/o Connectors
The connector is under the passenger side front seat. The wire passes through a grommet in the floor.
Old Aug 8, 2006 | 07:19 AM
Oh thanks for the advise, I already took out my passenger seat.. it doesnt look to difficult to get the $42.72 replacement oxygen sensor. but what are the chances of it actually being the corrent thread pattern? I cant return it, and i just wanna make sure it will actually screw in.
Old Aug 8, 2006 | 08:03 AM
Myszkewicz's Avatar
The thread pattern should be the same, it's a pretty universal thread. It's the number of wires you need to get right (2- 3- or 4-wire, you want the 4-wire), and then which wire goes where in the plug.
Also, secondhand information tells me it's sometimes difficult to solder to the silicone-jacketed wires that it is likely to have. If you have trouble getting solder to stick (if you solder your wires instead of crimp), wipe the stripped ends down with an alcohol pad, then put a little flux on 'em. Try to keep the splice inside the car, where it won't be exposed to the weather.
It should come with a diagram of the wiring for the sensor, telling you which wire is what. If you need the diagram for the wiring of the car to match up the wires, hit me up via PM and I'll send you a link to the diagram.
Old Aug 14, 2007 | 08:17 PM
samj601's Avatar
does anyone have any experience with these walker o2 sensors? they are plug and play like oem and cost about half...just wondering if they are any good.
Old Aug 14, 2007 | 08:28 PM
otter's Avatar
EvoM Administrator
I've had trouble figuring out our O2 sensors and never got around to solving the issue. Outside of the OEM (Bosch) sensor that costs over $200, I haven't figured out what fits, other than taking an universal sensor and splicing it in. Different websites point at different sensors with different connectors. Someone has to pull the stock sensor and look at the connector and go from there.
Old Aug 14, 2007 | 08:42 PM
samj601's Avatar
the dealership wants +$300 for a new one. i just put my catback on and in the process i phucked up the o2 sensor. right now, i'm using an universal one that my friend gave me but i don't think i spliced the wires correctly and now the cel light is on. i might just go ahead and get one of those walker ones. arent all o2 sensors pretty much the same except for the length of the wire and harnesses?
Old Aug 15, 2007 | 11:48 PM
migs647's Avatar
Hey guys,
On my Girl's OZ Rally I put a plug&play one in the front (bosch) and a bosch w/o a connector after the cat. I reused the old plug. It wasn't very hard to splice and the wires were the same color. Just cut it so you give yourself enough room and use 16gauge crimp connectors, you'll be up and running for ~$75.
Old Aug 16, 2007 | 06:32 AM
otter's Avatar
EvoM Administrator
Minor differences between some, but yeah, pretty much all the same. When you splice it in, do it with a good soldering job.
Old Sep 11, 2007 | 11:01 AM
lancer02Josh's Avatar
you can change the o2 sensor just under the passanger seat? its not something you have to go under the car for? anyone have any kind of instructions for removing/ installing the o2 sensors
Old Sep 11, 2007 | 11:06 AM
migs647's Avatar
It was kinda a figure of speech. It's under the seat under the car. You need to definitely be under the car as it's on the exhaust piping behind the cat.
Old Sep 11, 2007 | 11:34 AM
haha ok thats what i thought .. i thought that sounded weird.. its not hard to get to right.. then you just have to unscrew it splice the wires and your set right
Old Sep 13, 2007 | 12:25 AM
guerejo's Avatar
Did you get the right one?
Jesussaves1
Feb 27, 2013 11:33 PM
Beluga
Lancer Engine Tech
May 1, 2011 11:28 PM
sioux90
Oct 24, 2010 12:20 AM
Swankzer
Lancer Troubleshooting
15
Jul 11, 2008 04:57 PM
crypto
Lancer Engine Tech
32
Jul 19, 2006 12:29 AM
