ralliart ac knobs
ralliart ac knobs
I was just wondering if anyone else on here had problems with there dash knobs that control the ac and heater?? Mine will not switch over to the red area for the heater and I have hear form a couple people that they have the same problem
Sounds like there is a problem with the cable. Because of this, half way is probably now full heat. When you turn it past that, the cable bunches and pushes the knob back to the half way point. My bet is that when you turn the knob all the way to cold, it is not actually setting the internal mechanism to full cold. It's probably really only going about half way to cold. The cable goes down by your right leg under the dash. When you turn the knob, you can see the cable actuate the flapper. Check it out for any visible issues.
Gazika
Mar 31, 2016 11:27 PM
kingjhay723
12
Mar 23, 2014 07:13 PM
