Wen I Crank My Car?
Old Jan 19, 2007 | 10:21 AM
MikeKondilis's Avatar
Wen I Crank My Car?
When I go in my car and crank it, it doesn't start right away, it happened about 3 times to me. What do you think is wrong with it?
Old Jan 19, 2007 | 10:24 AM
Smike's Avatar
how old are the spark plugs and wires? when it cranks does its sound like each crank is weaker and weaker (starter)?
Old Jan 19, 2007 | 10:49 AM
I don't know, but my car is do for service at 24,000 and I have 24,100 so when I ever go there. I am going to tel them to check it out. No it doesn't sound like its getting weaker it just takes longer to start
Old Jan 19, 2007 | 10:55 AM
TouringBubble's Avatar
Check the plugs and fuel filter.
Old Jan 19, 2007 | 04:29 PM
heartagram71's Avatar
i have sort of the same problem, but its not an occuring thing, for me it usually happens if i forget to turn off the AC or heater and i turn off the car...it sounds like it wont start then does, weakly...but like i said its only happened a couple of times...
Old Jan 19, 2007 | 05:53 PM
^^ that might be it... I never paid much attention If my heat was on. I probably did because it is kind of cold here in Charlotte
Old Jan 19, 2007 | 06:25 PM
Myszkewicz's Avatar
Plugs should be fine at 24,000 miles, and the fuel filter is in the tank, as part of the pump assembly.
Old Jan 19, 2007 | 10:49 PM
bruce988jl's Avatar
I have that problem in the mornin during cold starts... Figured it was normal, one time it took 5 cranks so go figure... It gets pretty damned cold up here in boston, so i've gotten used to long cranks...
Old Jan 19, 2007 | 11:15 PM
Edd's Avatar
Edd
this has happened to me after the car has stalled..... it takes longer to start after that.....
Old Jan 19, 2007 | 11:48 PM
captain150's Avatar
Probably fine. It's happened once for me. Where I had to stop cranking and then try again. Only once that happened and the weather has little to do with it. It starts just as quickly at -30C as it does at +30C. Of course, it just turns over more slowly (sometimes reeeeeeeeallly slowly).
Old Jan 20, 2007 | 08:59 AM
otter's Avatar
EvoM Administrator
Happens on very rare occasion to me, as well. No real pattern to it, just one of those random things.
Old Jan 20, 2007 | 09:02 AM
ralliart329's Avatar
RAs dont have spark plug wires.
nor11384
Apr 2, 2017 03:52 PM
Mauricio Evo IV
Sep 21, 2016 02:45 PM
ryanholder24
Aug 29, 2016 07:08 PM
real fast
Aug 11, 2014 09:13 PM
Shastamiknasta
Sep 13, 2012 06:50 PM
