10k miles between oil change?
Old Jun 17, 2008 | 11:42 AM
Skott2k's Avatar
According to Yahoo auto 3000 miles is a thing of the past and no longer needed at 3k but un upwards of 5k-10k. Heres the link, anyone know anymore about this or the vailidty of it for Mitsu Lancers? Im not very knowledgeable but i get an oil change every 3k so this could save some $$.
http://autos.yahoo.com/articles/auto...MzMDAwLW9pbA--
Old Jun 17, 2008 | 11:45 AM
Smike's Avatar
I have never bothered with 3k. Amsoil - 10k changes. I just check the oil level every race. 92k on the clock.
Old Jun 17, 2008 | 12:04 PM
otter's Avatar
EvoM Administrator
Indeed. I run 7500 with Amsoil, but with the results I get back on my oil analysis, I could do 10k without issue.
Old Jun 18, 2008 | 05:05 AM
Skott2k's Avatar
Thanks for the info, this is definatly going to save me a good bit of money. I was interested in trying out Amsoil like you both use but i cant seem to find it anywhere other than online.
Old Jun 18, 2008 | 05:13 AM
chuggychug's Avatar
Depends on the type of oil you use and how you drive the car.
~Chug
Old Jun 18, 2008 | 12:38 PM
Lancer7's Avatar
What is this Amsoil? Is it better than the Castro Syntec I use?
I've always changed every 4k just because it starts looking darker.
Old Jun 18, 2008 | 12:40 PM
Skott2k's Avatar
Im not sure i cant seem to find it any of the stores around here..however ive heard tons about royal purple and it seems to have come down quite a bit in price since i last checked, anyone use it?
Old Jun 18, 2008 | 12:42 PM
Smike's Avatar
Otter can talk about RP. Its not worth it.
Contact Oil Doc on here or go to amsoil.com - you can order directly online.
Old Jun 18, 2008 | 12:44 PM
Lancer7's Avatar
Dealer locator...
http://www.amsoil.com/dealerlocatorresults/
Old Jun 18, 2008 | 12:47 PM
samj601's Avatar
10k even on an evo?
Old Jun 18, 2008 | 12:48 PM
Lancer7's Avatar
Seems kinda pricey.
Old Jun 18, 2008 | 12:59 PM
EvoBroMA's Avatar
i don't recommend 10K on mobil 1. mobil 1 turns to **** after 6K. enough to make my oil pressure sensor go crazy.
i almost overfilled - because i thought i was low.
Old Jun 18, 2008 | 01:34 PM
otter's Avatar
EvoM Administrator
Yes, and oil color isn't a good indicator of wear, contamination is, and you need to have oil analyized to know how contaminated it is.
RP, put simply, fails at standardized oil testing, particularly shear testing. RP dumped tons of money into marketing and used non-standardized tests to tout their product, but it really doesn't hold up as well as they claim.
Seems kinda pricey.
When I order it via OilDoc, by the case, it ends up costing about the same per quart as Mobil 1. (~5.99) Plus, it holds up a lot longer.
Old Jun 18, 2008 | 07:13 PM
Oil Doc's Avatar
Seeing this is a Ralliart thread, this applies to Normally Aspirated Engines ONLY.
Even with AMSOIL, on Turbo Charged vehicles, it is only recommended to the longest OEM Service Interval.
The Recommended change intervals by AMSOIL are for unmodified, daily drivers.
Any modifications, Especially air Filters, will shorten the life of the oil as will driving conditions.
It also depends on the oil used. AMSOIL has a Hydro-Cracked Product, XL-7500and then goes to the AMO 10W-40 which is a 15,000 change interval, then the ASL 5W-30 and ATM 10W-30 which are 25,000...
Again, for daily drivers....And the use of the AMSOIL EA Series Filter is required unless you are going to change filters at the OEM Change Interval.
In a Non-Turbo'd car such as the Ralliart, I would expect most of our oils to go the 10,000 interval with no problems. Any except the XL and European oils.
Doc
Old Jun 18, 2008 | 07:23 PM
Oil Doc's Avatar
www.3000milemyth.org
I have more from Lubes N Greases that I will try and get onto my website by next week
Doc
dboz
Future Lancer / Evo Models
73
Apr 4, 2011 12:25 PM
thejoshster
Mar 21, 2011 12:41 PM
Inzanesrt4
Northwest Region
20
Feb 28, 2007 03:50 PM
JustinTheGIMP
West Region
Dec 11, 2006 11:06 PM
