battery drain help?!?!?!
Old Mar 9, 2009 | 09:55 PM
  #31
Canada_Comp's Avatar
ah ha, knew it was the battery. nail them hard with the warranty =)
Old Mar 9, 2009 | 11:48 PM
  #32
joeyj's Avatar
still could be something else, wont find out till tomorrow, but i'd be really happy if thats all it was.
Old Mar 10, 2009 | 12:39 PM
  #33
SSP-Ralliart's Avatar
With batterys that are liquid filled if they are drained down 3 times maybe less for some they will die and become sulfated. Now with a gel type they last alot longer but require a trickle charge to fully charge. Now how exactly are they testing the car? Do they use a VAT40, miniVat by snapon/mac? AMP clamp? I am wondering since you have been there multiple times for the same issue. At least they found something. Let us know whatever else they find.
Old Mar 10, 2009 | 03:34 PM
  #34
joeyj's Avatar
ok, got it back from dealer, guy tested every facotry setting, starter, alternator, etc... and everything was good. so i was thinking where it could've been draining from and I totally facepalmed myself.
when i put the wideband controller in, it called for a 12v switched power source, but when i put it on the ecu, it must've been constantly draining it, and like SSP said, after the first couple drains, the battery went bad.
I had installed the wires for the wideband correctly originally, just to the wrong power source lol. just finished putting it on the 12v acc line off my stereo, (used the wiring diagram this time lol) and testing it, and everything works good. sheesh that was more trouble than I bargained for trying to cut corners when I installed the wideband. I just glad nothing else was damaged.
Old Mar 11, 2009 | 08:11 PM
  #35
good job.
Old Mar 12, 2009 | 12:19 AM
  #36
joeyj's Avatar
is that sarcasm?
because I probably deserve it for being some stupid. lol
Old Mar 12, 2009 | 05:22 PM
  #37
not at all. I am just glad you found it. Now you need to get your RA faster.
Old Mar 12, 2009 | 11:37 PM
  #38
joeyj's Avatar
im trying but i had a few ??'s about the piggy, if you could help plz see,
https://www.evolutionm.net/forums/en...k-maps-15.html
JTJB
Lancer Troubleshooting
17
Jul 14, 2025 08:06 AM
jdrames
Mar 25, 2021 10:35 AM
drew_pr
May 18, 2012 03:07 PM
4DOORGALLOR
Mar 11, 2010 02:16 PM
dustin11
Mar 15, 2009 09:46 AM
