Noob Dragstrip takeoff question..
Old Apr 27, 2009 | 08:50 PM
Hot_Carl's Avatar
Question Noob Dragstrip takeoff question..
i am about to take my 04 ralliart to the local dragstrip, but the sticky track has me worried, when any of you take off do u have ur car reved up already? (in M/T)?
My neighbor said to just take off normal and not to rev it up because i could break something int he car due to the prep.
what do you veterans do? and if you rev it up, what rpm are you going to?
if it helps the only mod i have is a sri...for now.
thanks
Old Apr 27, 2009 | 08:55 PM
FedEvo8's Avatar
If you take off normal, you'll have horrible 60' times.
They key to a good launch is getting the rpms in the power curve zone. Too little rpms will make the car bog, too high you'll just spin through 1st gear. Practice your launch and adjust your rpms.
Good luck and don't break anything!
Old Apr 27, 2009 | 09:04 PM
Hot_Carl's Avatar
Thanks alot,
im assuming around 4-5000 rpm then?
Old Apr 27, 2009 | 09:08 PM
UT_Evo's Avatar
Don't do it if you want to avoid any chance of breaking stuff... Just take off normal. Or accept the risks.
Old Apr 27, 2009 | 09:15 PM
Hot_Carl's Avatar
im going to do it either way, i kinda want to know which is the best way to do it though so i have a heads up to avoid damage thats all.
i know how to do it on an unprepped track...(street) im just worried becaue ive never done it on any type of prepping, maybe im just paranoid and there is nothing to worry about
thanks
Old Apr 27, 2009 | 09:49 PM
jzt's Avatar
jzt
Even though the track is prepped, you will not be able to take full advantage of it - you are still on street tires. I highly doubt you will break anything, you'll just spin.
Old Apr 27, 2009 | 09:51 PM
Lancerguy'03's Avatar
just take off as if you were on the street...and that will work with the track. you might have to go higher RPM though
Old Apr 27, 2009 | 10:30 PM
Hot_Carl's Avatar
ok sounds good. thanks for the quick responses.
Old Apr 28, 2009 | 02:08 AM
GearDownSon's Avatar
The one time i did take my car to drag i launched at around 3k.
I got the least wheel hop with that.
Old Apr 28, 2009 | 08:35 AM
otter's Avatar
EvoM Administrator
What GDS said. Don't rev too high, you'll just wheelhop halfway down the track (unless you have filled mounts.) 3k, don't dump the clutch, and you should be able to get a 2.2 60', which is about as good as you're going to get on street tires and no LSD with our car.
Old Apr 28, 2009 | 10:50 AM
Thomar's Avatar
^ hah. next to the boobies, worst advice ever :P
Old Apr 28, 2009 | 11:55 AM
Hot_Carl's Avatar
lmao....thanks for the advice guys! (and makin me laugh with the boobies comment)
Old Apr 28, 2009 | 01:56 PM
EightZero's Avatar
When I raced mine I kept it about 4K. I found that the key was to keep your revs above the MIVEC turn-on point because your car will act very sluggish until then. As for the rest, Otter is dead on; don't dump it and you'll get that 60'.
Old Apr 28, 2009 | 05:34 PM
Cj98's Avatar
I think I revved mine somewhere between 3k and 3.5k. Pulled of a 2.2 60Ft and 15.5 @88
slowonder
Aug 9, 2012 09:14 AM
bigric09
17
Sep 27, 2009 11:17 AM
ice1874193
Dec 18, 2008 12:15 PM
kstpeter33
Oct 4, 2007 11:13 PM
riles
Driving Techniques
Dec 14, 2003 10:00 PM
