sputtering engine
Old Jul 25, 2009 | 12:40 PM
bboysyck's Avatar
Question sputtering engine
here is a quick question that has been buggin me for about a year, everytime i start my car she idles at 500 rpm then stalls out, and if i try to rev it, itll sputter at 2500 rpm, and if i floor it it only goes to 4000 rpm wit no sputtering, any of you gurus kno wat the problem is.
thanx in advance guys
Old Jul 25, 2009 | 06:41 PM
Arxylis's Avatar
Sounds like your car is in limp mode. Use a code puller to see what codes come up. You said this has been bugging you for about a year... Does your car drive normally after the initial stalling and sputtering?
Old Jul 26, 2009 | 01:12 AM
joeyj's Avatar
reset ecu by disconnecting negative terminal on battery, start up, let idle for 10 min, drive under 3k rpm for 15 min, turn off car, and see if problem persists or if CEL comes up, then pull code and post up for us to help.
Old Jul 26, 2009 | 01:51 AM
bboysyck's Avatar
i took it to advanced and they said that the computer was reading TPS and MAF was faulty, im downrange so i cant really get it fixed, lol, which is why im postin on here to see wat i could have my lil brother do (with out causein more harm to my baby, lol), the CEL is on cause my cat is cleaned out, dont ask why, my best friend thought it would be cool so he did it while i was at work, lol
Old Jul 26, 2009 | 04:17 AM
Thomar's Avatar
maf can be cleaned with contact cleaner.
tps eh.. i donno how much it costs but its easy to replace.
Old Jul 26, 2009 | 04:39 AM
D420mac's Avatar
Where are you at down range?
Old Jul 26, 2009 | 06:58 AM
bboysyck's Avatar
im jus north of saudi, across the persian gulf from iran, and i cleaned the maf wit a maf cleaner, and it still had the same problem. i was hopeing its as simple as jus replacing the tps. does anyone kno where i can get a tps?
Old Jul 26, 2009 | 07:52 AM
D420mac's Avatar
ok well good Luck I'm in afghanistan.
Old Jul 26, 2009 | 08:21 AM
otter's Avatar
EvoM Administrator
Please give the specific codes if you have them. Our car doesn't have a servicable TPS. It's probably the APPS that's failed, but would need the actual code your car threw to verify.
Old Jul 26, 2009 | 01:36 PM
bboysyck's Avatar
im sry i dont have this code, where is the APPS at?
Old Nov 6, 2009 | 09:56 AM
Ralliart2004's Avatar
I'm having a similar issue, but it would seem that mine is sputtering near when MIVEC kicks in. It's feels like the engine is going to stall out on me or like a skip. It's between 2500 and 3500 RPM range. I called the Dealership and they were no help, they told me that I could bring it in and do diagnostics, but it would be better to wait until it's a real problem so they could narrow it down to the actual problem. It is a real problem. It does it in all gears, but i have to be at a steady speed. Any help?
I was thinking it could be the valves, or an injector going bad???
Upon further research, I'm being led to the idea that the problem could be a faulty coil pack??? Or a dirty or faulty MAF??
Also, there is no SEL code so I have no way of telling exactly where the problem lies except that if definitely feels like the motor isn't getting something around that RPM range or that it's binding up in that range. It's hard to describe exactly how it feels, but I think that the binding up description might be the best I have.
Last edited by Ralliart2004; Nov 6, 2009 at 04:07 PM. Reason: Amplifying information
Saint47
Feb 23, 2017 11:42 AM
Igaly1021
Nov 7, 2015 05:18 PM
BoostingHard
Jul 28, 2015 03:52 PM
lbwilliams44
31
Jul 12, 2013 07:56 AM
wiggam11
Dec 7, 2009 03:09 PM
