P0141
Old Apr 11, 2010 | 04:00 PM
edbighead's Avatar
P0141
Hey started throwing this code two days ago. Haven't modified anything in particular that would cause a sensor 2 heater system malfunction. Is this just a sign the sensor is going bad cause the car runs perfectly normal and thats the only code i do get. Any input is sure appreciated.
Old Apr 11, 2010 | 05:16 PM
otter's Avatar
EvoM Administrator
Most of the time it's a sign that the sensor is on the way out.
Old Apr 21, 2010 | 05:54 AM
edbighead's Avatar
so a new symptom has arrived, a miss. its very slight but i can hear it and sometimes feel it. this is probaly the o2 sensor huh,
who makes a good one. i have read that the bosch ones are junk. not looking to spend the 317 bucks autozone wants for a factory replacement though either. i found a denzo or something like that online for 119 or a bosch for 108
Old Apr 24, 2010 | 01:11 AM
joeyj's Avatar
I've had a bosch wideband o2 sensor in my car for over a year and it works great if that helps, but you're gonna need narrowband for stock o2 sensor.....
Old Jun 14, 2011 | 10:52 AM
shadovarian's Avatar
My piggyback is simulating the rear o2 sensor signal but the heater circuit code is still popping up p0141. I know that if I purchased evoflash I could get rid of it but I don't have the extra cash right now. Does the p0141 code cause the car to run any differently?
Old Jun 14, 2011 | 07:31 PM
Darewood's Avatar
Here you go
http://www.obd-codes.com/p0141
Old Oct 31, 2011 | 06:49 PM
That doesn't help. That specifies that the rear02 sensor is going out it will cause that. But my rear o2 isn't going out it is just plain gone.
The signal is being simulated so it should appear that the signal from the rear o2 is *functioning* normally. But does just the rear 02 heater make the car malfunction?
Old Nov 1, 2011 | 11:53 AM
roblaza's Avatar
Thread successfully jacked.
Old Nov 1, 2011 | 02:41 PM
deathsythe99's Avatar
lol yes indeed.
Old Nov 1, 2011 | 02:43 PM
i already made a thread on this code. and the websites givin to me.
https://www.evolutionm.net/forums/04...141-p0136.html
GodRealm06
Jul 9, 2015 02:36 AM
OC
Jul 4, 2015 09:07 AM
702RSevo
19
Jul 8, 2009 04:47 PM
DOUGLAS
14
Feb 3, 2009 07:00 PM
chinto
May 26, 2005 01:53 PM
