Headlight Issue
Old Sep 4, 2011 | 03:33 PM
Vro0oom's Avatar
Headlight Issue
So it appears that my passenger side headlight has decided not to work. The passenger daytime running and the low beams seem to be angry at me (not turning on). Both headlights work when I turn my high beams on though.
I've replaced both bulbs as well as the fuses to no avail. I'm getting a little frustrated and would love some help
Cheers dudes!
Old Sep 4, 2011 | 03:50 PM
roblaza's Avatar
Check the wires that go onto the plug. The could have come loose from the plug, or they may have broke in half all together...
Old Sep 5, 2011 | 01:32 AM
05raslw's Avatar
you may have ran to bot of a bulb and melted the plastic around the connectors I did with mine. u can upgrade with a plug and play jumper from racinglab.com and they have a slection of lights to
Old Sep 5, 2011 | 07:32 AM
CrAnSwIcK's Avatar
relay? i'll check the wire diagram tonight, and post here if i find anything.
Old Sep 5, 2011 | 12:14 PM
Vro0oom's Avatar
Thanks a lot dude
It sucks my car came without a manual and finding anything diagram wise online has been difficult.
The wires all seem to be in good condition so I'm thinking it's gotta be the relay as well, now I just gotta find it :P
Old Sep 5, 2011 | 01:13 PM
CrAnSwIcK's Avatar
fuse 18, in the under hood fuse box, it's 10A check that one, get back to me if it's no good.
Old Sep 5, 2011 | 02:56 PM
Vro0oom's Avatar
I changed the fuse and it still won't turn on. Damn that light lol
Old Sep 5, 2011 | 04:50 PM
CrAnSwIcK's Avatar
it's not the relay, cause one relay for each high and low (2 total) control both head lamps, the fuses are after that, so possibilities are: connection from relay to fuse, fuse to lamp, lamp to ground. that's all there is in the circuit as far as i could see...PM me if you can read a wiring diagram, i'll get you what you need, if you need help just ask, i'm an avionics systems technician, wiring is my specialty
Old Sep 5, 2011 | 04:56 PM
Vro0oom's Avatar
Thanks a lot, Crans, I appreciate it.
Old Sep 5, 2011 | 10:50 PM
nerdbotSKRA's Avatar
If that doesn't ring true either, the next thing I'd look at is the multi-switch itself. Weird things like what you're describing can happen if the switch is bad. Hopefully it's just a relay.
(if there's the off chance your car is from the states, and has an aftermarket DRL system, I'd take a peek at it as well)
Old Oct 6, 2020 | 05:17 PM
Ivangromov5's Avatar
Same problem please help!
I have the same problem with my 2008 evo x. Tried everything
low beams won’t turn on
trief swapping headlights replay fuses switches
still won’t turn on
any help?
cts4g63
Apr 11, 2016 08:32 AM
tbaird58
Feb 26, 2016 12:42 PM
lancerguy0208
Lancer Troubleshooting
Apr 25, 2011 09:41 PM
slatermvp
Dec 31, 2010 07:07 PM
DrBump471
Jan 20, 2005 03:25 PM
