starter problems again....
Old Dec 23, 2011 | 11:15 AM
Resurrected RA's Avatar
I have been having the same issue. Every now and then I get a CEL and this code:
P0335: Crankshaft Position Sensor A Circuit
Not sure if the 2 instances are related. In my research the CEL will reset after 40 successful starts. Which it did a few months ago. This time I reset the code with the Torque app (one the best apps I have ever bought.) via a bluetooth ECU dongle.
I have a new starter sitting in the garage that I may not have had to purchase.
Old Dec 27, 2011 | 05:26 AM
nekkidlad's Avatar
yeah i had that code before as well but not now...i cleared it with a code reader everytime i got it..since it was fine anyway...im not sure it was related or not either...
before the starter wouldnt do anything...the lights wouldnt dim or flicker...it wouldnt click....now the starter just makes this crazy growling noise, the lights dim, and flicker...(already got new a battery)...(again, 3rd time since i got the car)
i sold my starter for scrap a few days after i swapped it..u have it sitting there and could potentially use it...
i guess if u really wanted to take it to auto zone or w/e and get it tested make sure it was really bad or not...at least starting only sometimes is better than not starting at all...
Old Dec 28, 2011 | 12:38 PM
nekkidlad's Avatar
finally was able to reach somebody at the place i ordered it from, and they said they'd send out a replacement and then i just need to mail the old one back as a return...
(since i installed the new on in mid october...hope its not the same ordeal in 3 months...again)
Old Jan 13, 2012 | 11:41 AM
nekkidlad's Avatar
finally got starter in on monday...
just to see exactly what it did (even tho i knew it wast working) i bench tested the starter...
all it did was actuate the solenoid...the starter didint spin at all...
so im kinda confused what that weird growling noise it was making was...but w/e...now it starts fine and theres no more noises...
Old Feb 10, 2012 | 02:39 PM
Lgkaos's Avatar
Veteran: Air Force
So did that fix it? A new starter?
I'm having the exact same problems on my 06 Evo.
https://www.evolutionm.net/forums/ev...lem-whine.html
But I removed my starter and had it tested at Autozone and it checked out fine.
Old Feb 11, 2012 | 10:42 PM
RacerX-Ralliart's Avatar
I work at a parts store and its not rare that some rebuilt and even some new ones we have go out in 6-12 months while others last the life of the car.. the noise was prolly the Bendix gear hitting the flywheel teeth... I don't like autozone I had them test a battery they said it was good and tested the starter and they said it was bad I put a stater in no start it was the battery good thing it wasn't my car... I wouldn't put a 50 dollar starter on my DD and hope it doesn't go out you get what you pay for
Old Mar 31, 2012 | 08:44 PM
deathsythe99's Avatar
did this fix the problem??? my car didnt want to start today once after 6 times of turning the key it cranked over
Old Oct 1, 2012 | 11:33 AM
irvgotti's Avatar
i have a 2006 2.4 mivec lancer ralliart automatic and i have the same problem. about five to six months ago i had to change the starter solenoid and the problem stoped till now. once again it keeps doing the random problem of not turning on. any one has more ideas???
hatesposers
Feb 16, 2023 05:35 PM
wazzelby
Mar 29, 2017 06:28 AM
wazzelby
Jul 18, 2015 05:46 PM
evocivicmarc88
Jan 1, 2012 08:25 PM
nekkidlad
Oct 31, 2011 05:16 AM
