P2173. Bogging problems. Fix?
Old Jun 4, 2012 | 12:53 PM
MarkChamorro's Avatar
Hey guys my car is running like **** all of a sudden and threw p2173. Any Ideas? Dont think it's spark Plugs.
Also when I try to start my car it starts and stalls. I have to pump the gas once and it fires up and idles
Major Edit: Buy a MAF sensor if you get this code! Fixed mine and other owner's issues
Edit 1 month later: okay we'll I made another thread of how I'm hesitating t high Rpms, but now I'm getting symptoms of what happened in this thread but no cel. When I get on the gas it goes forward but at a noticeable difference, like it barely accelerates, and when I shift I shift normally, but the car kicks forward when Ii get on the gas then smoothly accelerates.
Old Jun 4, 2012 | 01:09 PM
Update: I have rrm piggyback. And AEM sri
The code is an improper air mixture or something
I cleaned my MAF as well, still bogging.
Old Jun 4, 2012 | 06:22 PM
Myszkewicz's Avatar
Not really much to go on, other than it points to your MAF. My guess is a dodgy connection at the Piggy, where you cut and spliced into the MAF signal wire. I used to have problems with my car bogging if I had a passenger and they bumped the mess of wiring hanging under the ECU with their leg while I was driving. I took out the spade connectors I had in there (was supposed to be temporary anyway), and soldered and heat-shrink-wrapped the connections. No more problems.
Check your wiring by the ECU, specifically the MAF signal wire. Make sure it's got a good, solid connection on both wires, and that they are not shorting out to anything else.
Originally Posted by Mitsu FSM
DTC P2173: Abnormal Intake Air Amount
TECHNICAL DESCRIPTION
• ECM decides the allowable
intake air amount in accordance with the engine
speed and the target opening angle of throttle
valve.
• ECM checks whether the
actual intake air amount is more than the allow-
able intake air amount.
DESCRIPTIONS OF MONITOR METHODS
The actual intake air amount is more than the allow-
MONITOR EXECUTION
Continuous
DTC SET CONDITIONS
Check Conditions
• Engine is running.
Judgment Criteria
• The actual intake air amount is more than the
allowable intake air amount for 1.5 seconds.
OBD-II DRIVE CYCLE PATTERN
None.
TROUBLESHOOTING HINTS (The most likely
causes for this code to be set are: )
• Mass airflow sensor failed.
• Throttle valve faulty operation.
• Throttle position sensor failed.
• ECM failed.
Old Jun 4, 2012 | 09:53 PM
Thanks I'll check the piggy bro
Old Jun 5, 2012 | 05:18 AM
ianmaki's Avatar
Try to reset your ecu.. Unplug your battery
Old Jun 5, 2012 | 06:03 AM
Yea that sounds good, I'll try that when I get out of school. I'll update
Old Jun 5, 2012 | 05:06 PM
Got the MAF sensor, I reset the ECU, let it idle for 15 minutes+. And when I put it in gear, go, then hold the clutch in it stalls. I have had this issue before but for some dumb reason I decided to keep the car alive by pumping the accelerator and I start driving. Flooring it to be honest for about 1 minute. Got home after the test drive and it stalled out ( saw that coming) but when I had this same issue before, I'd just restart it and let it learn to idle. But now it starts then stalls out, which never happened to me before. So I disconnected and let the ECU reset again bc I remembered I have the piggyback and need to drive normal for however long (100 miles or so). Hope this helps the idle issue. Any input helps
Old Jun 5, 2012 | 07:45 PM
keithislegit's Avatar
Same issue I had. I bought a new Accelorator Pedal Position Sensor.
Old Jun 6, 2012 | 09:43 AM
I forgot who said it, but apparently there was a TPS recall for our cars, I assume that's the same thing as accelerator pedal position sensor
Old Jun 6, 2012 | 11:24 AM
CrAnSwIcK's Avatar
it was Brent (OttRalliart05) and i'm not sure if he was referring the APPS or TPS, so people call the APPS a TPS, when actually the TPS is inside the throttle body, and the APPS is what your accelerator cable connects to...
Old Jun 6, 2012 | 04:56 PM
Well after driving in traffic and the car stalling while in traffic, it finally learned to idle lol. So all in all steps I took were, 1) buy MAF sensor after throwing the CEL code (P2173). 2) install (straight forward for a noob like me) 3) reset ecu 4) learn idle 5) drive happy also no need to disconnect or even touch the ECM/Piggy
Old Jun 6, 2012 | 05:54 PM
RalliartN's Avatar
Now get rid of the damned oiled air filter so it doesn't happen again. Use one designed to be dry.
Old Jun 6, 2012 | 07:22 PM
I had no idea the AEM sri was oiled lol. Best dry filter?
Edit: it is dry flow
Old Jun 28, 2012 | 04:25 PM
Big edit at first post
mtn007
Mar 23, 2026 02:07 PM
JohnBradley
May 2, 2019 02:47 AM
sirchumpalot
27
Nov 28, 2012 12:07 PM
MarkChamorro
Jul 14, 2012 10:20 PM
iceman1680
Aug 10, 2010 07:39 PM
