Hesitation at 5k+
Old Jun 24, 2012 | 03:26 PM
MarkChamorro's Avatar
Hesitation at 5k+
As the title says, when I'm WOT, at the 5k on Mark I get some hesitation the gain speed, then hesitation again. Just replaced the MAF sensor so I guess count that out, also need a valve adjustment due to ticking...also I just put in a serpentine belt yesterday but I think it'd done it prior to installation as well. P.s. as for the serp belt....it whistles like a spooling turbo at low to 3k rpm... Normal? lol
Old Jun 24, 2012 | 09:45 PM
CrAnSwIcK's Avatar
the whistle in my experience with two lancers is generally the power steering pump...
can you scan or datalog? can you post a video?
Old Jun 25, 2012 | 10:12 AM
I can't scan/data log, noob here :/ and I have no idea how to do that (part of the reason I want to visit Canada this summer and maybe meet up) . And video, very well able to do I'll be back with the whistle, and hesitation.
Edit: Forgot to mention, I have a piggyback, disconnecting it will be a last resort option I suppose.
Old Jun 28, 2012 | 04:30 PM
Okay well my camera isn't turning on so I ordered one. But something else is coming up...symptoms are coming up that are familiar to this thread I posted. https://www.evolutionm.net/forums/04...blems-fix.html
When I hit the accel pedal, it moves forward but not as "powerful" as it should normally, and when I shift and hit the gas. The car jerks forward then smooths out. TPS?
Go an disconnect the piggyback, see what happens
Edit: well oh well wire going to engine MAF sensor was disconnected...let's see if it gets fixed..if it does I bought a MAF sensor for no reason -_-
Old Jun 28, 2012 | 04:55 PM
CrAnSwIcK's Avatar
lol, that could be a problem, lol
Old Jun 28, 2012 | 05:16 PM
Lmao she's now running fine happy/upset I dumped 160 for a MAF. Welp she's fixed....now to get rid of that ticking...
Old Jun 28, 2012 | 05:35 PM
CrAnSwIcK's Avatar
injector tick or rocker tick? also check timing belt
Old Jun 28, 2012 | 05:56 PM
It's rocker tick, need valves adjusted. And I just test drove my car, idk it doesn't hesitate..but it feels slow, like I felt like first gear took forever to get through.
Old Jun 28, 2012 | 08:55 PM
CrAnSwIcK's Avatar
if you have an android, or symbian smartphone you can get apps that datalog through bluetooth. the OBDII adapter can be found on ebay for like $15 and the apps are like $10-20...or the adapter comes with PC software so you can use a laptop that has bluetooth...much cheaper though less capable than a tactrix cable...i use OBDscope on symbian...
but it's hard for me to relate, cause my first gear happens so fast i don't even really use it cause if i have 2800rpm in 2nd i'm hitting full boost and the car hooks up better, first just gets me moving...but if it's noticeably worse, do a tune up of anything you haven't done recently, and check your plugs.
Old Jun 28, 2012 | 11:44 PM
RacerX-Ralliart's Avatar
If you have the stock air box make sure the throttle cable is still hooked up right
Old Jun 29, 2012 | 08:18 AM
Any recommended Obd ii Bluetooth plug in? I got the program on my iPad. And racerx I have a AEM Sri bro
Old Jul 5, 2012 | 08:22 PM
04rallikid's Avatar
I wasted my time and did the valve lash adjustment, most of it was too tight by a bit, just under the recommended. I put it to the middle and still the same old noise, too much hassle in my opinion, gotta hold the screwdriver tight and steady while tightening the nut and use an angled set of feeler gauges.
Old Jul 8, 2012 | 01:51 PM
CrAnSwIcK's Avatar
could be injectors...they're like little relays, they go clickity click
valves will sounds very loud, like whacking a table with a yard stick several hundred times per minute...
Old Jul 10, 2012 | 07:09 PM
04rallikid's Avatar
yea Id agree with the pulsation noises
EVOEvolved
May 17, 2022 08:12 AM
xelloss
Outlander Sport
11
Nov 21, 2016 09:50 PM
mr06
Oct 19, 2016 10:13 AM
wewii
Jun 14, 2008 07:16 AM
RazoEvo
Oct 5, 2006 03:32 PM
