Ralliart 94 octane problem
Old Oct 15, 2012 | 02:33 PM
CrAnSwIcK's Avatar
Originally Posted by JTCB
I have a cel due to not having a cat but i got it checked after that and nothing else showed up. The APPS sensor is the one next to the throttle?
it's the sensor behind the passenger headlight...it's where the throttle cable ends... the TPS is in the throttle body...
Old Oct 15, 2012 | 02:44 PM
JTCB's Avatar
Oh ok then whats the sensor attached to the throttle control? Is that cruse control?
Old Oct 15, 2012 | 06:32 PM
CrAnSwIcK's Avatar
not sure what you mean by throttle control..
Old Oct 16, 2012 | 04:08 AM
bakuro117's Avatar
Accelerator Position Sensor (APS) here it is. Search finds all.
Part number is MR578861, it'll cost you about $200 and 10 minutes of your time to install.
Old Oct 16, 2012 | 02:32 PM
JTCB's Avatar
Throttle control (Thing you use to make the car rev under the hood) On the left of the headers at the begging on the throttle cable...
Old Oct 16, 2012 | 04:47 PM
CrAnSwIcK's Avatar
that's the accelerator pedal position sensor (APPS) in the picture above...
Old Oct 16, 2012 | 07:30 PM
mikemike396's Avatar
From my understanding. There is not direct connection between your foot (pedal) and the throttle body. The cable attached to your pedal goes to the "APPS" sensor shown above. Then this gets sent to the ECU and the ecu controls the throttle body. The APPS sensor is what is known to have issues with. I had to replace mine.
Old Oct 16, 2012 | 11:51 PM
CrAnSwIcK's Avatar
that's correct mike, inside the throttle body is the throttle control motor, and the throttle position sensor.
Teal2nnr
Feb 25, 2017 10:55 PM
insafa
Sep 15, 2014 09:58 AM
DiztortedGZR
Sep 5, 2014 03:59 AM
DiztortedGZR
Jun 27, 2014 02:33 PM
