air recirculation button doesn't work
Old Feb 11, 2013 | 08:31 AM
rzrxn's Avatar
hi guys..this problem has been here for a while but never got to ask about it..so the thing is, my air recirculation doesn't work..the button doesn't light up at all and i don't hear/feel any changes when i press on it..idk if it's just the bulb on the button itself or if it is working at all..i've searched an didn't find anything regarding this issue
please help!
thanks!
Old Feb 11, 2013 | 09:01 AM
slc-ralliart's Avatar
Is you position dial on defrost by chance. Recirculation won't work on defrost mode. If not check fuses first.
Old Feb 11, 2013 | 09:05 AM
rzrxn's Avatar
hi, thanks for the quick reply!
i've tried turning it on on every dial and it just doesnt wanna light up lol..i'll check the fuses and see if thats the root cause..do you by any chance know which fuse that would be? i have the fsm so i'll look through it when i get home..thanks so much again!
Old Feb 11, 2013 | 10:39 AM
I'm not sure on the fuse. At work and have limited resources. Could possibly be a bulb but I think that is unlikely.
Old Feb 11, 2013 | 11:44 AM
rzrxn's Avatar
Thanks for all your help! I'll be checking up on these threads from time to time so reply whenever you have time Thanks bro!
Old Feb 11, 2013 | 12:53 PM
Raikiri's Avatar
I think the recirculation button only works when the knob is selected to MaxAC? But I could be wrong. I never use recirculation personally though.
Old Feb 22, 2013 | 09:15 AM
rzrxn's Avatar
i tried everything it really doesn't work. hmm i'm thinking fuses but i still have to learn how to check them lol. i'll let you guys know if this problem gets solved in case someone else is having the same problem.
i'll keep you all posted!
Old Feb 23, 2013 | 03:43 AM
mikemike396's Avatar
Just a side note, mine works fine, (I think).. But when I switch it on I dont hear anything change. I believe all it does it pulls air from inside the cabin instead of outside. This is suppose to help on a hot day or cold day when the air outside is dramatically different then inside. Not sure that it is suppose to make a different sound. Doesn't seem like it should. Thats my 2 cents.
Old Feb 23, 2013 | 08:44 AM
rzrxn's Avatar
hmm that's weird..cos when i tried my friend's air recirc in his RSX i hear a difference..like it seems like the fan blows harder when it's OFF and when i turn it on the fan isn't blowing as hard as when it is OFF. the light on my air recirc doesn't even light up
Old Feb 26, 2013 | 08:01 PM
xbenbendx's Avatar
Bump has there been a solution to this?
LancerGuy93
Nov 3, 2015 03:49 AM
yacubkep
Apr 29, 2012 04:30 PM
dvd_mi
23
Jun 23, 2009 12:13 AM
iy
Apr 10, 2008 12:28 PM
BlaqueGhost
Lancer Troubleshooting
Dec 16, 2007 02:22 AM
