Evo Aluminum Radiator
Old Mar 8, 2013 | 10:16 AM
Darewood's Avatar
Hey guys, I did some searching already and I was finding that the Evo radiator will fit our cars. I was finding some conflicting info though, does it need any modification to fit or does it fit fine. Also we can reuse the stock fans?
EBAY LINK This is the one I'm looking at. My radiator just broke, the top plastic part is leaking terribly.
Old Mar 8, 2013 | 10:18 AM
Raikiri's Avatar
you'll need aftermarket fans most likely and will need to get a little creative with the tubing.
Old Mar 10, 2013 | 08:15 PM
Xenon84's Avatar
I used a mishimoto evo8 radiator to replace mine. Stock piping worked fine and I only could mount the main stock fan with one simple custom bracket...w the obx exhaust the second radiator wouldnt fin but it would fit up to a 10in aftermarket if mounted right.
Old Mar 11, 2013 | 07:23 AM
2006_RA's Avatar
I take it that the Evo radiator is thicker front to back then and is it that Evo fans would work ?
Old Mar 11, 2013 | 07:39 AM
lanzerralliart's Avatar
EvoM Super Moderator
Posting this should help from a visual aspect
https://www.evolutionm.net/forums/04...-radiator.html
Old Mar 11, 2013 | 08:48 AM
2006_RA's Avatar
Thanks Lanzer.
Old Mar 11, 2013 | 08:50 AM
nekkidlad's Avatar
well seeing as how it's already a thicker radiator(and inherent better cooling)and with the 1 fan missing, you think it'd work the same as stock and the 2nd fan theoretically wouldn't be needed?(provided the extra thickness cooling was about or the same as the OE rad w/ both fans)
which it likely isn't far off in daily driving...unless u're constantly racing u'd probably dont need the 2nd fan, right?
Old Mar 11, 2013 | 08:55 AM
ralliart610's Avatar
I had an aluminum evo rad in my ra. Everything bolted up except the main fan. It was close, so I just made my own bracket. I used a strip of stainless and drilled some holes in it. The fans fit with the obx header as well.
Old Mar 12, 2013 | 04:16 AM
Darewood's Avatar
Alright, thanks for the help everyone My father-in-law just went ahead and ordered a stock one. Found it reasonably cheap, if this one fails I'll go with the EVO one.
Old Mar 12, 2013 | 05:20 AM
nekkidlad's Avatar
i wonder if the aftermarket evo radiator fits?...(assuming the stock EVO radiator is thicker than the stock RA radiator bot not as thick as the aftermarket aluminum one...)
would it all fit with no issues(fans fitting like OE) and provide a kind of "intermediate cooling" between OE RA and the aftermarket aluminum EVO radiator?
Old Mar 12, 2013 | 06:08 AM
I remember dacib got an aftermarket no name radiator and fan kit off eBay that fit with a little modification. He didn't get any pics of it though and soon later traded the car so....
Old Mar 15, 2013 | 07:20 AM
Thats what I had, a no name aftermarket aluminum one for an evo. Only problem was what i said above.
4g63girl
Aug 2, 2018 09:15 PM
Scottr126
10
Oct 5, 2011 07:24 PM
Mellon Racing
Feb 28, 2011 01:42 PM
falcontx
12
Sep 30, 2010 05:36 PM
sykou
Lancer Aftermarket Forced Induction Tech
15
Mar 20, 2010 04:06 PM
