E brake adjustment?
Old Dec 28, 2013 | 12:42 PM
BrunoBoy650's Avatar
E brake adjustment?
I just replaced front and rear rotors and pads. My e brake seems to have to be pulled up all the way. How do you adjust it? Thanks
Old Dec 28, 2013 | 02:14 PM
CrAnSwIcK's Avatar
when you had the rear rotors off, did you get a good look at the brake shoes? the spacing between the bottom of the brake shoes is adjusted by the little splined/threaded spacer. the cable tension is adjusted under the center console.
Old Dec 28, 2013 | 02:19 PM
Supergoslow's Avatar
if you take your center console off to expose the e brake there is a 10mm nut underneath the handle in line with the cable you can turn clockwise to adjust tighter.
Old Dec 28, 2013 | 02:30 PM
I didn't pay attention to the rear shoes. I've never had a car that had that setup before. If I adjust the cables, will it tighten it up or do I have to do it at the rear shoes?
Old Dec 28, 2013 | 02:36 PM
just tighten the cable, it's simple and most of the time the only problem.
Old Dec 28, 2013 | 04:21 PM
CrAnSwIcK's Avatar
brake shoe spacing is important too, if you just tighten the cable, your shoes will only require a longer throw to make contact, and you'll end up with uneven wear. also not a bad idea to inspect and replace rusted springs and retaining pins.
Old Dec 28, 2013 | 04:59 PM
you are correct, these should be addressed. I am not saying tighten the cable and problem solved, both steps are equally as important.
[GBU]Moon
11
Apr 29, 2016 06:23 AM
evoniners
Oct 25, 2014 08:06 AM
NWEvoViii
28
Apr 25, 2014 10:59 PM
88888
Nov 21, 2011 09:43 AM
evo8 951
Jan 2, 2008 08:56 PM
