lower arm braces (h brace)
Old Aug 2, 2008, 03:37 PM
Canada_Comp's Avatar
Originally Posted by RotaryGreg
were the bolts hard to remove to install this brace? last thing i waana get into if i install one of these is having to replace a control arm or something because i tore the bushing out of it or something....also, why did you have to shave that part down? what did it interfere with?
Greg
When I was trying to measure the bushing it was really easy to get the bolt out, but you have to apply a lot of torque to get the bolt initially free, something like 150 ft-lbs, after that first initial crack, they can be loosened with your fingers.
as for the shaving down part, look on the left side of the picture and a little bit upwards oil filter access
Old Aug 5, 2008, 09:06 AM
RotaryGreg's Avatar
O, i see. thanks for the heads up. about shaving it for clearance on the filter, do you use the stubby mitsu filter? its hard to tell from the pic...im wondering if i could get away with it becaues i use that really stubby filter from mitsu (116 is the last three of the PN). nothin to it but to do it i gess. gonna get one of these really soon.
greg
Old Aug 13, 2008, 09:44 AM
BiCiRA's Avatar
greg
I think that even if you have a small filter, in order to take it out, when u unscrew it it comes down a lot... so the bar might get in your way anyways...
I'm buying this bar really soon also it will suffer a lot with my TEIN S-TECHS
Old Aug 13, 2008, 09:56 AM
BiCiRA's Avatar
Does this one fit our RA's!?!?!
I think it bolts on the opposite end of the control arm than the red one does... dunno?!
Old May 3, 2013, 11:15 AM
navyseals68's Avatar
Installing it
Hey i know this might be a long shot, but i was wondering when you installed it to the frame where your bolts short? my stock bolts wont bolt to it because they are small. did you use other bolts to connect to the frame. The back part of the brace.
thank you
Old May 3, 2013, 10:49 PM
Matt_Jagg7's Avatar
Link us to a proper H Brace, and it is confirmed that it will not work with OBX Header/downpipe?
Old May 4, 2013, 10:56 AM
OttRalliart05's Avatar
Originally Posted by migueralliart
This is the Hbrace installed.
looks great now remove the oil filter.
Old May 5, 2013, 08:17 AM
It looks great. It looks like mine, but I was wondering if you had to buy new bolts because they weren't long
Enough.
Old May 6, 2013, 07:18 AM
kapitolralliart's Avatar
guise....this thread is from 2008...
Old May 6, 2013, 07:54 AM
johnnycage's Avatar
Looking pretty sweet!
RenleyX
May 21, 2014 07:09 PM
marl
16
May 16, 2013 07:57 PM
dRifT iT
Dec 25, 2012 03:30 PM
pgmike
Lancer How Tos / Installations
Sep 22, 2004 05:58 PM
Quick Reply: lower arm braces (h brace)
