EcuFlash 09 Ralliart tables Vs. Evolution 10 tables
Old Dec 23, 2008 | 12:32 AM
  #46
madcows's Avatar
Originally Posted by gunzo
Yes it does I believe .. think I found it .. just need to test somemore .. problem doesn't always happens .. it only happens under part throttle under certain conditions .. but I fixed 1 thing .. it always happens around 30% throttle
Good work! Definitely keep us updated!
Old Dec 23, 2008 | 08:46 AM
  #47
pltek's Avatar
hi Gunzo, so i am not sure if i understand, so we are dealing with ecu v. tcu, engine power cut v. tansmission clutch disengagement. so that really gives us a lot of combinations of what and when to control
since getrag built the tranny, they can customize the gear ratios, shift points based on certain parameters and i would assume that the shift points would be what is controlled by the TCU (including driving mode programs) so lets assume the end goal here is to protect the tranny from excessive torque,
If ecu reads torque (airflow) then it can either force engine to go into limp mode or send request to TCU for tranny gear to disengage,
so which is it and when does it happen, and of course how can we change it get beyond this limit?
i spoke to somone at cobb and they say that you can raise the threshold by controling the airflow limit table ( i assume that its in the ECU)
what say you?
thank you
Old Dec 23, 2008 | 02:07 PM
  #48
madcows's Avatar
I wonder what would happen if you load the R/A with the MR program, and change the fuel maps among a few other things..
Old Dec 23, 2008 | 05:53 PM
  #49
gunzo's Avatar
what say you?
thank you
The big question is still WHO BUILT THE TRANSMISSION ..
It was ASSUMED to be getrag ..
I think you understand correctly ..
TCU (tranny) sends a signal to the ECU (Engine) for shift .. ECU references a table and sends back a YES /NO signal ..
If a NO signal is sent .. the gearbox goes into protection mode and frees the clutch .. the engine freerevs and trigger a transmission slip code ..
I hate this current ECU as it has multiple layers of protection .. The airflow limit which Cobb mentioned is 1 just of many .. once they exceed that .. it'll trigger another set of codes ..
Old Dec 23, 2008 | 11:41 PM
  #50
madcows's Avatar
How are you figuring this stuff out?
Old Dec 24, 2008 | 01:14 AM
  #51
RazorLab's Avatar
hit both of those already.
Old Dec 24, 2008 | 06:39 AM
  #52
pltek's Avatar
so you gotta an RA you working with?
Old Dec 24, 2008 | 05:57 PM
  #53
gunzo's Avatar
I can't fix what I don't know bryan ..
You're supposed to send me details
RPM / tps
load / timing
g/s
Dynoed torque / hp
where all the lights are triggered ..
Mine doesn't trigger, everything is good on my side ..
Merry Christmas !!
Old Jan 4, 2009 | 08:55 PM
  #54
GST Motorsports's Avatar
Getting a RA on the dyno testing with Ecuflash here in the next couple weeks...
Expect a full blown post/review.
Old Jan 5, 2009 | 06:20 AM
  #55
TTP Engineering's Avatar
RPM / tps
load / timing
g/s
Dynoed torque / hp
Merry Christmas !!
We have a number of Ralliarts in house weekly Richard. We'll get you your info asap.
razorlab
5165
Aug 11, 2024 07:56 PM
razorlab
E85 / Ethanol
115
Sep 14, 2019 12:28 PM
razorlab
Apr 2, 2016 11:01 PM
GST Motorsports
Evo X Dyno Results
117
Feb 16, 2010 12:32 PM
razorlab
Nov 3, 2008 12:00 AM
