Break-In Procedure
Old Feb 14, 2009 | 07:34 AM
otter's Avatar
EvoM Administrator
You don't need to break in the car, just drive it normally and it'll take care of itself.
Old Feb 14, 2009 | 07:35 AM
otter's Avatar
EvoM Administrator
Originally Posted by laksman91
So is it fine to use 16" right away? It's winter and I want to use steelies. I don't see why it'll be a problem, but might as well ask
If you use steelies, make sure you get good hubcaps. Steelies leave the hub exposed and can make future maintenance, such as axle swaps, a PITA.
Old Feb 14, 2009 | 07:48 AM
LanceR_11's Avatar
This.
Old Feb 14, 2009 | 11:32 AM
laksman91's Avatar
That's the thing. I suspect that the people at the tint shop mightve redlined it.
Old Feb 15, 2009 | 07:49 AM
otter's Avatar
EvoM Administrator
Your car is fine. I would, however, be pissed at the tint shop if they took your car for a joyride.
Old Feb 16, 2009 | 09:38 AM
Conor's Avatar
Did you compare mileage before/after? Either way, the car is probably just fine. Redline does not = car death. Especially not on a new car. You have fresh oil, perfect bearing clearances and, oh yeah.. the engine is designed to spin that fast.
The important thing is that you have the same size wheel/tire on all four corners and that the tires are worn evenly on each corner.
Otherwise you're just going to destroy your drivetrain...
Piro Fyre
23
May 15, 2010 12:34 PM
madcows
Feb 14, 2009 10:59 AM
MaxKanisha
Jul 2, 2007 08:45 AM
v8k1ller
Oct 31, 2005 07:47 PM
