AMS Project Lancer Ralliart
Old Mar 23, 2009 | 03:21 PM
  #136
EricJ@AMS's Avatar
Without launch control, a Ralliart with an Evo X turbo may launch VERY SLOWLY and run an even slower E.T. with a better mph. Someone is just going to have to try it.
Old Mar 23, 2009 | 04:36 PM
  #137
08Lancer89's Avatar
Ill just stick with your parts.....
Old Mar 23, 2009 | 06:04 PM
  #138
jazket's Avatar
Originally Posted by Euripides
Intake is diff for sure, not sure what else
+1 . That's what I was going to say. I think it's only that; RA's intake is smaller
Old Mar 23, 2009 | 06:21 PM
  #139
JONralli09's Avatar
the turbos are different, no twin scroll for us
Old Mar 24, 2009 | 05:34 AM
  #140
elpoole's Avatar
correct me if Im wrong on this but the cams are different as well.
Old Mar 24, 2009 | 05:51 AM
  #141
EsRt2evo's Avatar
I believe so. It would only make sense for them to be different.
Old Mar 24, 2009 | 06:42 AM
  #142
08Lancer89's Avatar
Yep yep
Old Mar 24, 2009 | 08:03 AM
  #143
Euripides's Avatar
Cams are the same
Old Mar 24, 2009 | 08:13 AM
  #144
EsRt2evo's Avatar
Cams are the same
source?
Old Mar 24, 2009 | 08:14 AM
  #145
EsRt2evo's Avatar
Hey Chris post up the overlay of the stock RA and stock gen coupe! I'd like to see how things are going with both.
Old Mar 24, 2009 | 08:58 AM
  #146
Bom's Evo's Avatar
Cams are the same
Anyone confirm this?? Part Numbers? I would think Mitsu would match the turbo to the cam.
Old Mar 24, 2009 | 08:59 AM
  #147
TheDriver11421's Avatar
cams are the same.
Old Mar 24, 2009 | 09:30 AM
  #148
Before the RA was officially released i remember older ralliart concepts having different cams, but they stuck with the evo cams for the official release. see below
http://www.edmunds.com/insideline/do...ticleId=127026
"A Lot of Engine
We're almost surprised to see Mitsu using a 2.0-liter engine in the 2009 Mitsubishi Lancer Ralliart, as Subaru and Mazda have moved on to larger-displacement, four-cylinders for their more favorable torque characteristics. Yet, after five minutes in the Ralliart, it's obvious Mitsu's decision has been the right one.
The engine itself is identical to the one in the Evo, right down to the 86mm-by-86mm bore and stroke, semi-closed-deck block and forged crankshaft and pistons. A Mitsubishi product planner tells us that the engineers considered using less aggressive camshaft profiles for the Ralliart, but decided to keep them unchanged. Even the compression ratio is identical at 9.0:1"
Old Mar 24, 2009 | 09:48 AM
  #149
Chris@AMS's Avatar
Ask and you shall recieve! This is stock for stock
Red is the Ralliart
Blue is the Genesis coupe
Old Mar 24, 2009 | 09:59 AM
  #150
jazket's Avatar
Red is the Ralliart
Incredible. Our power to the wheels loss ratio (I just made that term up) is higher compared to the Gen 2.0T.
I gotta have a Get 2.0T
