Adding a sunroof?!?
Old May 26, 2009 | 05:42 PM
RallyGoneEvo's Avatar
Adding a sunroof?!?
Hey guys, I found a wrecked 2008 lancer and their selling the sunroof for $350. It's the complete assembly. I have a few questions. Do Lancers have tubes running to the fender wells for water to run through? Is the switch in the front dome light assembly? Thanks guys.
Old May 26, 2009 | 09:53 PM
03chi-town0Z's Avatar
yes and yes. see if you can get the whole roof if its in good condition. believe it or not it all un-bolts and its less likely to have a leak. at least at the sunroof. just have to re-seal the windshields (front and back) and the roof mouldings and you'll be set. easier than cutting a hole in ur baby and you can always put it back to original
Old May 27, 2009 | 06:15 AM
Heliart's Avatar
look around in your yellowpage there may be places that does sunroof professionally and you're looking at somewhere between $1000-$1500....better than trying to cut open your roof yourself and improperly install the sunroof yourself....
Old May 27, 2009 | 06:32 AM
C H's Avatar
C H
You won't be able to install the factory sunroof your self.
You can get the cheesey glass pop up type put in that will eventually leak.
I really don't think it is a good idea to do, if you do it at least make sure a pro does it.
Old May 27, 2009 | 12:53 PM
I dont have any plans on installing it myself. REally I just wanted the place to mount the sunroof in and I'd do all the wiring.
Old May 27, 2009 | 08:59 PM
C H's Avatar
C H
You will have to get the headliner from the other car as well. I don't know if all the railing and mount points will be in your car. It is likely welded in at the factory making it a pain to get out and put in your car.
IMHO don't bother.
Old May 27, 2009 | 09:06 PM
GavinIX's Avatar
completely but this is the first tiburon owner ive seen on this site and is a member of new tib as well.
sorry for that haha... continue
Old May 28, 2009 | 05:56 AM
Heliart's Avatar
there's at least one more tiburon guy here....forgot his name...
Old May 28, 2009 | 06:49 AM
Drows's Avatar
I traded my 2004 Tiburon tuscany in on the RA :P
I loved the car and got more complements on that car then any car I've owned (even more then the RA, though I don't know why). It WAS gutless though heh.
Old May 28, 2009 | 12:58 PM
What if I bbuy the whole roof? I heard its bolted on and Id just have to replace the seals.
Old May 28, 2009 | 01:11 PM
C H's Avatar
C H
Pretty sure it would be spot welded, but if you take off the headliner you should be able to find out. Is the roof the same color, if not it could be expensive.
Old May 28, 2009 | 04:45 PM
No, it's black. but for the time being a black roof on a white car might look good.
Old May 28, 2009 | 06:59 PM
C H's Avatar
C H
Black would probably look cool.
ATTAHO
Nov 5, 2018 06:51 AM
hktrigguy
Oct 31, 2016 12:42 AM
auni93085
Jul 2, 2015 08:45 AM
Scottr126
Sep 27, 2013 01:51 AM
badev0
Apr 9, 2012 01:00 PM
