launch control
Old Oct 19, 2009 | 06:33 AM
lostirc's Avatar
launch control
Hey.
Someone correct me if I'm wrong but Ralliarts do not come with any kind of launch control system.
Without LC how are you guys getting a nice start off the line? My car pulls hard through every gear except when its in first and below 3,500, being able to launch at something like 2,000 would cut my 1/4mile time in half haha.
Is it vehicular suicide to rev up in N and knock the shifter into drive?
Old Oct 19, 2009 | 07:07 AM
akj237's Avatar
Originally Posted by lostirc
Hey.
It is pretty much suicide for the transmission to rev up the motor and then drop it from nuetral to drive. This has been discussed before. Try the link to this thread: https://www.evolutionm.net/forums/09...h-control.html
Old Oct 19, 2009 | 08:01 AM
bossssman38's Avatar
Neutral drops are a big no-no. Unless you have 10k for a new sst
Old Oct 19, 2009 | 08:30 AM
lostirc's Avatar
so, no N drops. What about holding the break and revving to around 2k?
Old Oct 19, 2009 | 08:32 AM
akj237's Avatar
Negative
Old Oct 19, 2009 | 08:45 AM
RevLimiter's Avatar
I have held down the brakes and accelerated to get a pretty good launch, beat some wrx and turbo civics with my stock RA, all due to the launch. BUT, the sst will tell you to "slow Down" after you launch that way a couple times. I suggest the ams tran cooler, that would help with that problem.
ambystom01's Avatar
It's not a torque converter based automatic, when you're revving the engine, the clutches are engaging slightly. Keep it up and you'll get a warning on your dash.
Old Oct 19, 2009 | 05:09 PM
Jyrk's Avatar
launching a car is very hard on it, doesnt matter if it has LC or not, the car will take a beating with any kind of launch.
There has been a few Evo MR tranny's to go BOOM from what seems like overly using the LC. Check out a few threads in the evox area about it.
Risk over reward. Risk the 10k tranny to be rewarded with beating the riced out civic (at the track of course)
Old Oct 20, 2009 | 07:47 AM
07outty's Avatar
try staging / launching using the hand brake instead of the foot brake.
it takes some practice....
......but there is far less "dead time" when you hit the gas pedal.
Old Oct 20, 2009 | 08:51 AM
akj237's Avatar
^ That's still putting added stress on the clutch discs an will probably cause a premature transmission failure. But then again, it's your car so you can do what you want. Like everyone said it's not like this transmission is cheap to replace. Hell even the transmission fluid cost an arm and a leg.
Old Oct 20, 2009 | 08:54 AM
clifhanger87's Avatar
as long as you're not holding it at a high rpm for a long time, it should be fine. i've brake-boost launched mine 40+ times at auto-x events, but i only let it get up to 2800-3000 rpm for less than a second usually. nothing's gone wrong yet.
the big problem with that is heat. if you hold it for a long time, you'll build up a lot of heat and possibly damage your clutches.
Old Oct 20, 2009 | 11:08 AM
07outty's Avatar
......using the hand brake instead of the foot brake ...
...........does not put any more "stress' on the clutch pack.
i did not say . use the hand brake and then rev the engine.
Old Oct 20, 2009 | 11:22 AM
akj237's Avatar
Call me crazy but I'm having a hard time understanding why everyone is trying to drag a Ralliart. The car wasn't meant for that. It's a Rally car. Hell all the reviews I read and even on my test drive proved that the Ralliart is a dog from a dead stop. I know if I wanted a drag car I wouldn't have bought a Ralliart because it's not exactly a torque monster. It would take a hell of a lot of money to make it a good drag car.
Old Oct 20, 2009 | 11:27 AM
ambystom01's Avatar
Ummm...the Ralliart isn't a rally car, there isn't a car produced today that can claim that. To me the Ralliart is the same as the Evo X MR, STI, WRX, whatever, it's intended to be a quick and fun daily driver, nothing more, nothing less.
Old Oct 20, 2009 | 11:33 AM
akj237's Avatar
Ok, so it's not a rally car but that's what the Ralliart, Evo, STI, and WRX were based off of and just turned into more practical daily drivers. It's like buying a sportbike. They're based off racing bikes but detuned and equiped for daily riding on the street not the track.
