RA Complaints Thread
Old Feb 28, 2010 | 11:45 AM
  #151
Silver09RA's Avatar
Has anyone here noticed a squeak while starting their car for the first time in a cold morning?It lasts for about a split second, but then the squeak won't happen if you try to turn off then start the car right back up... possibly the belt? I only have 3200 miles on the car, and it shouldn't have a loose belt already right?
Old Feb 28, 2010 | 02:14 PM
  #152
Jyrk's Avatar
I think the one you're talking about is the sound from the SST.. I could be wrong, but alot of people have this "squeal" on cold starts. Many have thought its the SST.. No real proof if it is or not, just what people thought the sound is coming from.
Old Feb 28, 2010 | 03:47 PM
  #153
billyboy1's Avatar
with the shocking seats the ra comes with, it necessitated the seating position to be more forward than normal - the seats then kinda worked, but the A pillar is right in the way when looking through corners - haha, solve one problem and end up with another
Old Mar 1, 2010 | 09:18 AM
  #154
boondoc's Avatar
Originally Posted by Silver09RA
.....possibly the belt? I only have 3200 miles on the car, and it shouldn't have a loose belt already right?
The Lancers no longer use belts. Its a timing chain.
Old Mar 1, 2010 | 09:26 AM
  #155
Silver09RA's Avatar
Thanks for the info man... I'll try to take a note of where its coming from next time.
I know they use timing chains instead of timing belts... but I'm referring to the belt for the water pump, alternator, power steering etc. sorry for the confusion man.
Old Mar 1, 2010 | 09:36 AM
  #156
boondoc's Avatar
Its all good no worries . I hate that sound too but I don't even think the mechanics at the dealer even know where it comes from.
Old Mar 1, 2010 | 05:15 PM
  #157
EricJ@AMS's Avatar
I'm pretty sure that screeching noise is the AC compressor clutch. Most of us have our climate controls set where the AC is usually cycling and when its real cold, the clutch screeches when it first grabs.
Old Mar 2, 2010 | 07:01 AM
  #158
DarkCloud2049's Avatar
It has happend to me and I have 12k on it. My brothers GTS does the same once in a while itll squeak at startup but goes away quickly.
Old Mar 2, 2010 | 07:02 AM
  #159
It has happend to me but goes away very quickly. I have 12k on it. It also has happend to my brothers GTS on startup.
Old Mar 3, 2010 | 07:47 PM
  #160
scafel19's Avatar
Wish the car came with a warning telling me when the weather and the roads may be "perfect" because I really enjoy the warning when they may be icy. What a waste of electronics. Dealer said they can't reprogram that.
Old Mar 6, 2010 | 12:20 AM
  #161
jRox's Avatar
Does that really bother you? It's only there for like 3 seconds.
Old Mar 6, 2010 | 07:14 AM
  #162
BigGreenMachine's Avatar
The car telling me the roads are "Perfect" would be pretty mint. = ]
Complaint...flat spins on dry roads are causing excessive wear to all four tires.
Old Mar 6, 2010 | 07:40 AM
  #163
scafel19's Avatar
Only because I'm riding without TPMS in my winter wheels. I reset the Service Light, then the Icy roads warning comes on and then I have to reset the Service Light again.
I just think it is funny that a car needs an info light like that on it. I wonder if I would be able to take Mitsu to court because the warning light on the car states that the roads are icy, but in actuallity they are not, and that effects my mind on how I drive.
Old Mar 6, 2010 | 07:42 AM
  #164
Ph3n0m's Avatar
Veteran: Marine Corp
Now why the hell would you want to do that.... I'll bet you can't it says the roads may be icy, not are icy...
Old Mar 6, 2010 | 02:07 PM
  #165
brads09lancerGT's Avatar
The warning doesn't say the roads are Icy, it says possibly icy. Also u should always drive more careful when it gets cooler not just cause the warning comes on, black ice can happen in a second. Suing mits over a possible icy roads warning is without a doubt top 5 dumbest thing I've ever heard in my life.
I have no tpms on my winters either and my icy roads warning comes on then right away does the tpms one so I only have to press the button once. I'm pretty sure that every new car has to have the icy road warning. My parents new 2010 Avalanche does so does my friends Forte Koup.
