Stock 1/4 Mile ET?
14.3 if you brake-boost without over-heating
good luck with that
Option that works best for me and gives me 8.4s 1/8 times with 2.2 60':
ASC:OFF + Auto + Sport + AWC:SNOW
Launching method: Hold Brake Pedal, Rev past 3000 (not past 3500 or you'll get a Slow Down warning and NO launch for you until you let go of the gas and wait 1-2 seconds for the TC-SST to re-engange) let go of the brake and hold your steering wheel tight! (no need to hold it tight really... these cars are slow as hell haha)
good luck with that
Mid 14's. I would recommend that if you brake boost not to go much higher than 2500 RPM for 2 seconds. There have been a few TC-SST fatalities and heat is generally the problem. The car will go pretty good if you leave it in Auto/Sport/Tarmac. If you decide to shift yourself remember the TC-SST doesn't shift really fast near redline.
If you flash the ECU and you are going to be in the High 13's.
Just noticed you recently joined, have you broken in the car yet? If not it will be slower and I would say it is unwise to bring it to the strip until broken in, but it is your car.
good luck with that
good luck with that
Why do you put it in SNOW mode?
I ran 14.187 @ 94.89 bone stock full weight in my Sportback Ralliart with my fat *** (240 lb.) driving. Oh, and my car was broken in 1/4 mile at a time
The above time was ran with less than 1000 miles on the odometer.
Keith
The above time was ran with less than 1000 miles on the odometer.Keith
Taking the car to track for the first time this evening, what kind of times should i expect from my bone stock 09 Ralliart?
