AMS Small battery Install Location
I picked up a factory RF sub to finally gain some trunk space back from my giant Kicker 12L7 that took up my entire trunk. This also meant it was time to get my AMS small battery mounted in a more permanent home. The styrofoam dividers couldn't work any better for this. The battery sticks up maybe 2mm higher than the inlay for the piece of cardboard but it still works fine and is unnoticeable once the carpet is in.
Yes I had it through this last winter. Couple days for below zero and I didn't have any problem starting. Initially I had an amp and sub in the trunk, so I already had a 4GA wire ran to the front so cranking is a bit slower than stock. My next step will be to run some thicker guage wire when I get around to it.
I just tapped the power into the nut on the side of the old battery terminal just as you would installing a amp. Taped the connection and ziptied the old battery terminals out of the way. That way if I ever decide to ditch the intake I can put the old battery tray in and no one would ever know I had the battery in the trunk.
I was contemplating on just getting the ams bracket and going with a braille battery. Braille has a battery the same weight and almost the same size but 1067 crank amps instead of 680.
You could take it to any car audio install shop. Basically it's the same as installing an amplifier in the trunk. I'd say you would have less than $100 in labor + wire + battery.
Finally got my 0GA wire installed. What a world of difference even in warm temperatures. After a bit of research 4GA is really only good for 75A which is far too little when starting in cold weather or even warm weather for that matter.
thats why i said what i did. technically it should be vented out of the car some way and if he ever intends on competing in any type of sanctioned event he'll need some sort of external kill switch/cutoff as well
yeah, IASCA (one of the car stereo competition organizations) would definitely doc points for that, if not disqualify, if there's no venting to outside the car and the battery isn't the sealed type. However, since the battery ~is~ on its side and isn't leaking fluids, that would indicate that it is a sealed (non-venting) battery.
That battery you could mount on your dashboard and it would pass tech. It's a drycell battery.
However, in that photo above it doesn't actually look like it's *bolted* down so yes that wouldn't pass tech and is dangerous. It really needs to be mounted.
would still need to properly secure and kill switch . if only i felt better about drilling into my car...the front plate mount was bad enough
