O2 Sensor CEL
Old Oct 11, 2010 | 06:10 PM
bsvaton's Avatar
O2 Sensor CEL
OK so I am finally done dealing with this problem and I found something that might help others. After installing the turbo back AMS exhaust I tried using the viberant o2 spacer to turn off the CEL. I tired all 3 sizes at within the first few hours the CEL would come back on. So I am not sure if anyone can find the specs on the difference between a RA 02 sensor and a Evo GSR but there is diffently a visual difference. I purchased a used o2 sensor from a guy on this forum who drives a 08 GSR. The pigtail still fits but it was not a big and blocky as mine. I am guessing that maybe the o2 from a Evo has a different readout range than a RA. I am not a o2 genius or nothing but I do know electronics and I am guess the o2 sensors have a certain high/low range on them that causes a CEL to be thrown. Input anyone? Also wanted to post this for those like me that could not get the CEL to stay off to give this a try.
Old Oct 11, 2010 | 10:07 PM
evil03's Avatar
urmm if your tuned you shouldnt have this problem...
but any how
here is how to fix that problem i am stacked 3 deep (1) HELP! 42009 (2) HELP! 42002 HELP! last one is drilled out 1/2 to fit the o2 sensor.. 12k no problem
here is a link to how to do it....
http://www.*******.com/forums/showthread.php?t=3116
Mod: for some reason the link gets blocked
pm me for info
Old Oct 12, 2010 | 04:45 AM
bsvaton's Avatar
It was AMS tuned with a stock exhaust and I don't think adding an exhaust gives,me a good enough reason to retune ........this could be another way for people like me that have to travel 10 hours or more to find a good tuner. and I am not sure if you understand what I am saying because if you did you would not have posted an anti fouler instructional forum......ALREADY TRIED IT DID NOT WORK........and if you actually read the forum you linked there are people that still got a CEL....I am simply throwing a new idea out there that worked for me
Old Oct 12, 2010 | 11:50 AM
stfuad's Avatar
Do you have a scan tool? If you do, mind doing a reading on the sensor itself?
Old Oct 12, 2010 | 01:09 PM
robyn402's Avatar
did you go with the ams access port tune or openport....
if you went the cobb route they can disable the rear 02 sensor in the programming of the tune,
Old Oct 13, 2010 | 02:55 PM
bsvaton's Avatar
I went to AMS and they tuned on the dyno.
Old Oct 13, 2010 | 09:49 PM
robyn402's Avatar
****ty so u have no means of flashing urself... well i think theres a thread in the evo X section about cancelling 02 sensors with that means of tuning, use that info and get someone local to make the change
Old Oct 13, 2010 | 09:51 PM
robyn402's Avatar
oops typed in wrong tab... delete if you see this
vendetta92
Jun 7, 2020 03:14 PM
Bird1002
Jul 25, 2012 07:48 AM
awd2gen
Apr 15, 2009 06:24 PM
EvoDan2004
Jul 14, 2008 06:30 PM
bboy_RES
Sep 21, 2007 09:31 PM
