How you drive will determine the longevity of SST
Old Jan 11, 2011 | 08:46 PM
2010 Rallihead's Avatar
Originally Posted by zx-319
I encountered a similar issue in manual/sport mode. Downshifted too gears and floored it right away. The car was accelerating but not even close to what I would expect and the RPM remained steady (I don't remember exactly but something like 5K RPM) for about 2 seconds... I'm no expert but this felt pretty much like a lots of clutch slipping...
Honestly, I'm surprised this happened... From what the salesman told me, the car has some rev-matching. So it should not matter if I'm WOT or if I have the foot off the pedal... When engaging the clutches the ECU should be temporarily ignoring the inputs from the throttle pedal and just adjust the throttle itself to adjust the RPM and as soon as the clutches are safely engaged, open the throttle at the degree I want. That's the way I would program it, or at least something like that.
agree as well, had this happen too, the RPMs raced to redline, but I wasn't going anywhere lol..
Old Jan 11, 2011 | 08:54 PM
pcload1etter's Avatar
What if you just drive it in manual mode all the time, do these types of problems still occur?
Old Jan 12, 2011 | 04:49 AM
zx-319's Avatar
The benefit of always driving in manual is that you will control when it shifts. This is beneficial is situation where you stop very often and drive at low speed (i.e.: in traffic) because you can stay in a lower gear when you know you're going to stop very soon.
But, driving in manual mode will usually lead to worse fuel consumption due to the fact the auto/normal mode is always going for the highest possible gear for your current speed.
Old Jan 14, 2011 | 06:50 PM
TaKectrLANCER's Avatar
So what if you use engine braking alot? I currently drive a stick and I notice that my revs are really high when driving on the street/merging because I get more torque at the pedal, OOOR if I need to slow down I don't have to brake.
Does this cause anymore wear on the TC than a normal manual? The reason why I even switched to manual is because I killed my 03 lancer's auto tranny by upshifting/engine braking too often : /
engine braking is how I like to drive, it makes all the difference between a road shark or road kill : /
Old Jan 15, 2011 | 06:56 AM
zx-319's Avatar
I would worry more about the engine if you are continously reving it. As for engine breaking, it depends on how you do it. If you are accelerating WOT and suddenly engine breaking with closed throttle and no actual brake assistance, the transmission's gears are taking the hit. I am not sure it is a good thing.
If you have a restless driving as you seam to mention, you better make use of your brakes a lot more than engine breaking. Brakes pads and rotors costs practically nothing compared to as transmission rebuild or replacement (whatever transmission you have) and you can replace it at home with no special tools in minutes...
6466Animal
Dec 12, 2015 10:25 PM
adtalmeda
Lancer Engine Tech
Nov 25, 2014 08:41 AM
jmichetti
Feb 22, 2014 02:55 PM
migs647
Pacific Northwest
103
Aug 18, 2012 02:23 PM
toyotabike
Jul 6, 2010 08:31 PM
