AEM Intake For Ralliart!
Can't say if it's faster, probably not, the RA turbo is pretty well fed by the stock system, and is probably too small to really make use of this thing... not to mention driving it hard would be a bad idea with it leaning the car out so much. This is the last step between me and a RAD Lite. That should happen before the end of the year.
What are your cruising a/f's? Thanks for posting btw. That excellent info.
after installing the intake i got p0133 cel, which is o2 sensor low circuit. im not sure if its related to the intake and not having a tune or what but i took it to the dealership since im friends with service and they claimed that there is a TSB for this specific CEL and that they are supposed to reflash my ecu, i ended taking my car home cause i didnt want to lose my GST tune. anyone else get this light?
This intake is designed for stock map, or custom tune. You can't in-between it and expect perfect results. Would you custom tune the RA turbo, then throw on an X turbo, and expect it to run perfectly...?
Seriously tho, if you look at the GST Base Map's Fuel Map and compare it to a stock tune Fuel Map, it will be pretty obvious why his car us running so lean now.
Sorry totalOwnage I didn't specify, my post was a response to EyeDreamt,
I ordered the AEM intake (RA version) as part of my X-Swap. I'll post up with results, including what needs to fabricated for this to work with the X turbo.
Yet another car ridiculously leaned out by this intake.
I wasn't saying it isn't to be expected. There was a lot of speculation that the intake would be fine with the basemap, I was just pointing out there are now numerous examples of the fact that it isn't.
Ah, yes. In that regard it appears to be correct. This intake is NOT intended to be used with the GST Base Map. It WILL require a CUSTOM TUNE, or conversely a completely STOCK TUNE (as funny as that sounds).
