AEM Intake For Ralliart!
Old Aug 28, 2014 | 07:54 PM
  #181
RalliFast's Avatar
I put in my AEM intake and I was incredibly disapointed, until we diagnosed and found one of the holes in the intake wasn't completely drilled out. It was giving false readings to the wastegate and I was loosing 10 psi.
I'm sure this has been written up before, I'm not the only one but I can't believe that AEM let this through, I thought they would have better quality control.
Old Aug 29, 2014 | 11:41 AM
  #182
hotkupa's Avatar
Originally Posted by WookieBlue
Definitely one of my favorite RA engine bays i have seen on here! Did you send everything off to be powdercoated?
Negative. I used the engine paint from AutoZone!
Old Aug 29, 2014 | 12:27 PM
  #183
WookieBlue's Avatar
wow really, was not expecting that haha? Was it just the spray engine enamel?
Old Mar 12, 2017 | 09:07 AM
  #184
robban87's Avatar
Time to revive this old thread :P
I just installed an AEM intake kit on my 2010 RA. Indeed, the clamp that attached the lower tube on the turbo was a real pain in the *** to loosen!
I notice a clear increase in power, and the sound is awesome! I really enjoy hearing the turbo spool up from inside the car!
I did did get a little bit worried though when I noticed it was not as smooth anymore when idling, and as I researched it I came across a lot of posts in this forum regarding the AEM intake making the car run a lot leaner. Now I got worried at first, researching the increase in AFR some ppl have seen at WOT, comparing it to the stock WOT AFR. Naturally I don't want to get knocking and ruin my engine.
But reading through this thread, and judging from the info on the AEM website, I got a little bit calmer since it truly seems like you can run this intake with the stock tune. Sure, it makes it run a little bit leaner, but it doesn't seem to me that I would face any big risks by not tuning my car for this intake. Mind you, this is the only mod I have on my car at the moment.
Any thoughts from someone more experienced with running this intake on the RA is appreciated!
Old Mar 12, 2017 | 06:21 PM
  #185
Slee256's Avatar
Do a couple more key mods and then you can download this FREE badass tune and get some REAL power increases.
2010 AUS/EDM - 98 RON - BoostPill - TBE - AEM Intake - V3.1
Old Mar 13, 2017 | 10:28 AM
  #186
robban87's Avatar
Thanks.. but I think I'll let my local tuner have a look at it
Old Mar 13, 2017 | 12:02 PM
  #187
Kaitos's Avatar
Just be careful with the local tuner. If your tuner doesn't bother touching the SST tables, it could ruin your transmission. Have to make sure the tuner is familiar with the SST platform.
Old Mar 13, 2017 | 12:09 PM
  #188
robban87's Avatar
They should be since they are the leading evo tuner in Sweden
Any ideas on the AEM intake with stock tune from anyone?
Old Mar 14, 2017 | 03:38 AM
  #189
Laza's Avatar
Been running the AEM intake (evo intake pipe + AEM filter, not the AEM kit) with stock tune for 3-4 years now. No issues. Not too many proper tuners here (and the US maps obviously aren't compatible with EU cars) so I haven't even bothered to try to get one.
[EDIT] specified intake type
Old Mar 15, 2017 | 02:31 PM
  #190
robban87's Avatar
FYI I made an unboxing + before vs after on this intake
mRVRsport
Outlander Sport
970
Dec 27, 2024 09:53 AM
infected
Outlander Sport
250
Oct 11, 2018 09:36 AM
AlvinHuyN
Mar 12, 2018 03:34 AM
ziad
Jun 11, 2017 12:38 PM
Nast_Nas
Outlander Sport
76
May 3, 2017 08:16 AM
