Projectors for RA
Old May 6, 2011 | 07:46 AM
komilp13's Avatar
Originally Posted by newmitsuowner
but i could use that without any issues right? dont really need projectors
how would you wire up the halos? Or is it just a simple plug-n-play?
Old May 6, 2011 | 08:23 AM
newmitsuowner's Avatar
no. i would send in the both headlights and they would do it for me. then send them back. so i can just install them again. plug n play i believe. regardless i would get them reinstalled by a professional
Old May 6, 2011 | 05:29 PM
03chi-town0Z's Avatar
In this other thread (https://www.evolutionm.net/forums/la...s-oem-hid.html), they used EVO X projectors on a Lancer. I am assuming that since the wiring is projector-ready in all lancer models, if we can get our hands on a RA or regular Lancer projectors, it should still work. What are your thoughts?
Correct. Any lancer family model projector headlamp will fit
Old May 11, 2011 | 07:55 PM
komilp13's Avatar
I found someone on the forums who is selling their EVO X projectors and basically the dealer told them that it would fit any models from 2008 to 2010. I am thinking that they should work with an 09 RA. I don't want to buy them and then get stuck with them if they don't work out. These things are not cheap.
Old May 17, 2011 | 06:40 AM
komilp13's Avatar
Just noticed your post.
I did not call your dealership since that was a bit out of my way. It would be nice to talk to a technician at a dealership instead of a service rep. Most of the service reps are pretty much how you mentioned.
So, I did purchase a projector housing complete with ballasts & bulbs from a seller on these forums. We had an IM conversation going on related to this last week. Can I purchase a leveler switch from the dealership & simply hookup?
Originally Posted by 03chi-town0Z
All you need to do to get it all functioning is to swap complete assemblies into the car as mentioned before (housings/bulbs/ballasts/leveler if so desired) and then we can go in to the ETACS, which is basically a BCM+, and enable all of the HID operating functions so the car will recognize and behave properly.
I am not sure I understand what you mean? Sorry, I am a computer geek by day and a wanna-be car freak by nights. Do I need to bring the car to a dealership for this?
In another post you mention ...
Yep. Also, as evidenced in the movie, you really don't need to program the car, but you need to watch out for the drl function interfering with the ballast operation. You can just buy a drl bypass kit from jrox or the like, and then your fogs will still function as fogs.
Otherwise, if you wanted to be legit and have the fogs function as drls, if you live in an area that requires them or some such thing, then the computer can be programmed to accommodate that and make your fogs your drls, just like OEM configuration.
So, then if I bring my car to your dealership, will you be able to make the fogs as drls? how much would that be?
Old May 17, 2011 | 01:51 PM
Basically, yes. You would buy the leveler switch from us and install it where the blank currently sits on the left of your dash. The car is pre-wired for it, it is just plugged into the back of nothing.
We would then go into the car's computer using our scan-tool laptop and reset the parameters so the car recognizes the fogs as drl's and the headlamps having the hid's with the leveler switch installed.
You can skip this whole process and just install the lenses, ballasts, etc. and just work it like normal off of your existing light stalk, but you'd never have the leveling feature and would need some sort of drl-disable harness so you don't burn out the stock hid ballasts.
Old May 18, 2011 | 06:28 AM
komilp13's Avatar
I have a drl-disable harness from Jrox that I currently have installed with my HIDs to disable them as DRLs.
So, then I can install the projectors & hook up the harness to turn off the DRLs. But if the wiring is the ready for projectors, why would the ballasts burn out?
After I have them installed, can I bring my car to your dealership to do the for HIDs & the leveler switch? How much would that cost? Will the projectors work without the leveler switch?
Old May 20, 2011 | 08:23 PM
Jrox' harness would be perfect if you don't plan on doing the changes in the ETACS. The reason that you'd need it is because the car will still think it has standard halogen lights installed and will continue to send a low-voltage drl signal through the low-beam headlamp wiring, potentially causing the ballasts to flicker on and off causing them to wear and burn out prematurely.
The only other thing I would want to make sure of, before doing the reprogram, is to make sure you wouldn't need a new non-fog equipped turn signal stalk (which I don't think you'd need) and just double check that the wiring stays the same and no pins need to be swapped if you do require a different switch but don't want to spend the money (again I think it'll be fine, but I will double check and get back to you)
The projectors will work just fine without the programming or the leveler switch, but it's definitely a cool feature to have, especially for all the guys who want to be able to run the fogs without the headlights on. Like mentioned before though, you just need to make sure you use the drl disable if you're not going to do a full conversion.
We can definitely do the reprogramming for you, and anyone else intersted. I'll get a discounted price for you, and anyone through evom that wants it done (or any other service or parts for that matter) and I'll pm you as soon as I get it approved and let you know how much.
Old May 20, 2011 | 09:06 PM
komilp13's Avatar
Thanks man. I'll be waiting for your reply.
Old May 27, 2011 | 07:27 AM
komilp13's Avatar
03chi-town0Z ..... did u have an update for us?
Unknwn
Jan 26, 2019 07:13 AM
LancEric
08+ Lancer Show / Shine
44
Feb 3, 2015 01:52 PM
am22
May 11, 2011 10:13 PM
omniprobe
Jun 5, 2010 06:46 PM
Evo VIII 4G63
Mar 15, 2009 06:45 PM
