mod advice... where to go next? (on a budget)
Old Dec 20, 2011 | 01:36 PM
  #61
sstevojr's Avatar
short doesn't an o2 housing.
Old Dec 20, 2011 | 02:16 PM
  #62
Chaz17's Avatar
so i keep the stock o2 housing on it with the short or do i just not need an o2 housing?...
Old Dec 20, 2011 | 02:40 PM
  #63
sstevojr's Avatar
You need to keep the stock o2 housing, as no one makes an aftermarket one for the RA trubo (that I know of). The o2 housing is actually the biggest restriction in the exhaust system; think of how restrictive the cat is even at 4' from the turbo (maybe 3' or 5', just an estimate), and then place a restriction 6" from the turbine
It's not nearly so bad on the RA, because the turbo is limited by flow anyways (i.e. harder to "clog" with exhaust gases), but like all bolt-ons, every bit helps
Old Dec 20, 2011 | 03:03 PM
  #64
Chaz17's Avatar
thank you. so would the UR long downpipe + HFC be a better idea than the short one + hfc?
Old Dec 20, 2011 | 03:16 PM
  #65
sstevojr's Avatar
To get every last bit of power you can, yes. It's a personal decision whether the cost is worth the gain. We haven't seen empirical evidence as to how much, but I would expect mid-rpm-range improvements to be the biggest gain.
Old Dec 20, 2011 | 06:56 PM
  #66
03chi-town0Z's Avatar
Someone should experiment and send the RA o2 housing out for a complete port job. Then pair it with the short dp of choice and check the results. I'd bet for the low, low cost the results might be interesting.
Send me your stocker...
Old Dec 21, 2011 | 10:08 PM
  #67
Chaz17's Avatar
may be a real dumb question but would a boost controller help protect from running rich or lean?...
Jenkins651
Feb 23, 2016 08:07 PM
LandoCommando
Aug 16, 2015 03:02 PM
danielazo
25
Apr 20, 2015 07:35 AM
HimynameisWillzyx
Feb 28, 2012 03:08 PM
