Does the RA have a simpler version of the Evo X's AWD?
Old Nov 19, 2012 | 01:54 PM
DjRags604's Avatar
Or is it a completely different system altogether? I've read online that it was lifted from the Evo IX but couldn't find anything to back up forum talk...
Old Nov 20, 2012 | 07:19 AM
Veronica's Avatar
^true. there is confusion due to early press releases saying 'EVO IX components'
AFAIK it is a RA-specific part and 'simpler' (cheaper) than the EVO X unit.
Old Nov 20, 2012 | 03:18 PM
gaabbee's Avatar
front differential and transfer case are exact same as the evo x mr. The rear differential is something else. The ralliart rear is a mechanical limited slip diff while the evo has active yaw control diff.
Old Nov 20, 2012 | 05:54 PM
DjRags604's Avatar
Good to know. Thank you both.
Old Nov 20, 2012 | 07:13 PM
deprydation's Avatar
Wonder how hard it would be to install an Evo X diff in the RA.
Old Nov 20, 2012 | 07:49 PM
sblvro's Avatar
it has evo 9 awd components.
Old Nov 20, 2012 | 08:47 PM
richardjh's Avatar
Rich
Old Nov 20, 2012 | 10:59 PM
RazorLab's Avatar
Transmission is same as MR except for gear ratios. Transfer case is same as MR with ACD and all.
Rear diff is *like* the USDM Evo 8/9 because it does not have AYC like the Evo 10 Therefore it doesn't have "SAWC". However it is a different physical unit then the Evo 8/9. This also makes it stronger than the Evo 10.
Old Nov 22, 2012 | 03:37 PM
NFSLancerRA's Avatar
Old Nov 22, 2012 | 03:38 PM
People go to great lengths to get rid of the Evo X diff...
Old Dec 10, 2012 | 12:23 AM
dangina's Avatar
why is that? whats wrong with the sawc?
Old Dec 10, 2012 | 05:31 AM
TrailBrake's Avatar
Bumpity bump bump.
What are the issues with Evo X rear diff? Just wondering
Old Dec 10, 2012 | 06:29 AM
gaabbee's Avatar
Originally Posted by TrailBrake
Bumpity bump bump.
Pretty sure they can't handle a lot of power. Also from reviews they are not very good in a slalom course
Old Dec 10, 2012 | 07:59 AM
TrailBrake's Avatar
Interesting, thanks for the info.
Completely anecdotal, but my previous car had in it's final model years a very early implementation of an electronic rear limited-slip differential (0-100%). Lockup wasn't as smooth and predictable as the completely mechanical LSD found in older models, so it was often 'downgraded' to the older model's setup.
Sometimes simpler is better
Old Dec 21, 2012 | 09:28 PM
hixlancer's Avatar
Veteran: Army
simpler is ALWAYS better.
EvoRinga
Feb 20, 2011 06:17 AM
Evo999
Aug 7, 2006 04:58 PM
monmashq
25
Dec 21, 2005 02:57 AM
x7eVoLuTiOn7x
May 3, 2005 08:34 AM
bmaga123
Apr 12, 2005 08:51 PM
