Question about goin to the snow for first time
Old Jan 9, 2013 | 10:11 AM
Dbzguy's Avatar
So I might go to the mountains to hit up the snow and was wondering if the AWD system is good enough or am I going to need chains?
Thanks!
Old Jan 9, 2013 | 10:16 AM
p1llar's Avatar
My RA has been excellent in the snow, mind you I have winter tires. The oem tires are said to be brutal in snow and on ice.
I've only had my RA stuck once and that was going through a section of 2ft of snow for about 30 yards, nearly made it through but my bumper acted as a plow and eventually got the frame hung up. 4WD Tacoma couldn't get me out, an Avalanche got me out after a good 20 minutes.
Old Jan 9, 2013 | 12:22 PM
sstevojr's Avatar
BAWAHAHAHAHAH
AHAHHAHAHAHAH
change tires, all good
Old Jan 9, 2013 | 05:24 PM
gaabbee's Avatar
Our awd is pretty much one of the best set ups you can get even better then some 4wds. You should have no problems. Drive slow and remember awd helps you go, not stop.
Old Jan 9, 2013 | 07:43 PM
xi's Avatar
xi
We have one of the best AWD setups in the world.
But EVERYONE in EVERY CAR has All Wheel Braking.
It's all up to your tires, honestly. The AWD is good when people think you have a fwd drive car and you can hang the tail out on every corner (much more fun doing it in snow tires because of the control I have vs. all seasons).
Old Jan 9, 2013 | 07:59 PM
SilverShadow03's Avatar
Do Not Use chains on an AWD car. Change your tires to snow tires or AS tires or don't risk it.
Have fun!
Old Jan 10, 2013 | 08:12 AM
Dbzguy's Avatar
Right on guys thanks... Im going to hook up some tires on sat anyways. Just wanted to be sure that everything would be cool
Old Jan 10, 2013 | 08:47 AM
crak's Avatar
http://www.bridgestonetire.ca/#blizzak
Blizzaks are a top end winter tire if you are looking for a recommendation.
Viegasjuice
Jan 7, 2014 04:16 PM
OC
Dec 12, 2013 07:51 PM
quadrophine
21
Apr 17, 2013 09:21 AM
5963
Jan 24, 2013 11:31 PM
