Accidentally ran stock Ecu on Boost Pill
Old Jan 10, 2013 | 07:33 AM
jlog1506's Avatar
So ive been running the Gts Basemap for a while now but yesterday i decided to run the stock ecu to see the difference between the maps. Not even realizing that the boost pill was still installed. So while doing my first pull around 5k-6k boost cut off and it made this sound as if you just let off the gas on full throttle but a little worse. I immediately pulled over and thank god I have my laptop in the car. My question is do you guys think i did permanent damage to the car? The car ran fine after switching the maps. I feel so stupid
Old Jan 10, 2013 | 08:35 AM
szuto's Avatar
Don't do it again. You're probably luck that nothing happen -_-
Old Jan 10, 2013 | 09:25 AM
zebra4's Avatar
I would say you overboosted and the ECU cut the fuel. You should be alright.
Old Jan 10, 2013 | 07:58 PM
spekil's Avatar
That's why it's so important to run a boost gauge and afr gauge in thAt way you have a broader idea on what's going on to your car...
Old Jan 11, 2013 | 06:58 PM
jlog1506's Avatar
alright thanks guys... anybody else have opinions?
Tpriem10
Jul 10, 2014 06:05 AM
villero1834
Cobb AccessPORT
May 16, 2013 09:48 AM
n/atoboosted
11
Jan 3, 2013 02:23 AM
AMT
62
Jun 17, 2011 07:25 PM
rogue
Evo X Dyno Results
12
Apr 14, 2009 07:00 AM
