Trouble starting car - what is this warning light?
Old Jan 27, 2013 | 02:18 PM
gimpydingo's Avatar
Had some trouble starting the car this morning, tried to turn over but couldn't. Saw a warning light of a down arrow pointing to a rectangle under it. Can't find in the manual. Any idea?
Old Jan 27, 2013 | 03:12 PM
danike's Avatar
Isn't that the "hey turn the engine off dumbass" light I get everytime i open my car door for more than 10 seconds?
Old Jan 27, 2013 | 06:14 PM
initial_d2k's Avatar
i think thats the sign saying you can hold the INFO button to clear the msg? Like TPMS warning etc etc
Old Feb 1, 2013 | 10:07 PM
Dbzguy's Avatar
Usually its an arrow pointing to a button to clear what warning comes up
Old Feb 4, 2013 | 05:55 PM
spekil's Avatar
I just had the same issue with you. I have the evo x stock battery as I located mine in the trunk. I think what happen is that, if you keep holding the ignition to on position for too long, the battery loses charge.
I kept the ignition on for so long as the vehicle didn't want to turn over and I got lots of warning lights such as parking brake, abs light etc. I deflooded the engine by disconnecting the injectors + boosted the battery = worked!
Old Feb 4, 2013 | 06:19 PM
deprydation's Avatar
How exactly do you "flood" a fuel injected vehicle....
Old Feb 4, 2013 | 06:33 PM
spekil's Avatar
Move your vehicle from the front of your house to the your garage at the back of the house. Resulting to a fouled spark plug. Start vehicle and not enough spark. Keep cranking the engine then fuel keep coming in.
Dont your manual also says to hold down the accelerator pedal all the way to deflood your engine?
Old Feb 5, 2013 | 05:16 AM
Veronica's Avatar
^yes. That is the procedure.
Old Feb 5, 2013 | 10:56 AM
gimpydingo's Avatar
My light was just the door is open too long. Never a prob starting the car again, maybe the wife didn't hold it quite long enough when the morning was cold.
ivan308
Jun 6, 2017 06:01 AM
pitmac
Oct 18, 2016 07:46 PM
CottageLifer
Outlander Sport
Oct 7, 2016 05:10 PM
idiaroi
Aug 15, 2015 12:03 PM
