o2 and cat problems.
Old Apr 16, 2013 | 09:16 AM
krysko8's Avatar
Alright so i been trying to get my ralliart to pass inspection..at first the check engine was on for a slow reading front o2 sensor. After that got replaced, went back for a sticker and now says that the front o2 and cat are not ready, even though i drove over 100 miles after having it replaced. I do have a highflow cat and 3inch turbo back. Can this be ignored and flash a stock tune to pass then just flash my tune back? Or what. Thanks.
Old Apr 17, 2013 | 11:30 AM
krysko8's Avatar
Lots of views but no help?? Anyone have this kind of issue before?
Old Apr 17, 2013 | 11:51 AM
Risky Guy's Avatar
This may or may not help.
Try resetting ecu, disconnect battery terminals overnight.
Then re connect & drive at least 50 miles it should clear its own. Also you can go to autozone to clear the light before you reset.
Good luck
Old Apr 17, 2013 | 12:34 PM
krysko8's Avatar
Good luck
The check engine light has been off since i changed the sensor. When the dealer plugs the car in for a sticker, then the print out says that the o2 is not ready along with the cat.(i've. Been told that if the front o2 isn't ready then the cat wont be ready either) But i will try to reset the ecu over night. Ill post results tomorrow. Thanks!
Old Apr 17, 2013 | 01:30 PM
Fuego's Avatar
Whoops I thought I posted here. :-( I agree with risky guy! Also if the cop gives u a ticket u just go to court and show them u were trying to work out the issue and bam! Case dismissed. Happened to me before. Fixed the issue and got the ticket on the way to get inspected lol
Old Apr 17, 2013 | 01:52 PM
nunyas's Avatar
worse comes to worse, you may need to flash back to a stock rom to pass the inspection. You'll be fine with a stock ROM and the cat back. The high flow cat ~might~ throw codes though...
Old Apr 17, 2013 | 03:43 PM
krysko8's Avatar
So the check engine light came back on for a slow reading o2 again!..idk what the problem is now since that o2 is brand new. Ill take it to the dealer tomorrow.
Old Apr 17, 2013 | 07:45 PM
nunyas's Avatar
do you have one of those O2 sensor spacer things?
Old Apr 17, 2013 | 10:08 PM
SUDDOTH 2's Avatar
my 2006 Ralliart has a p0421 code and i think its the 02 sensor as well. I has a similar issue on my 2003 Lancer ES, and it was the sensor so im not sure what to do. the Ralliart 02 sensor is a lot more money
Old Apr 18, 2013 | 03:30 PM
total0wnage's Avatar
That's your o2 sensor, use evoscan 2.8 to run codes not 2.9, it comes up with random code numbers
Old Apr 18, 2013 | 08:41 PM
Bom's Evo's Avatar
I'm using the Vibrant o2 spacer with the smallest pill. I can get away with no CEL for maybe a week.
I'm going to have to double it up or get a smaller pill that i'll have to drill out on my own.
I have a high flow cat as well...Sometimes, you gotta play with it.
Those custom ones usually work better because you can get stack them and have ones that have a bend too. Pretty much, you have to tune the space to let the right amount of exhaust to the o2 sensor.
On my beater, I was able to pass my regular car with the same code.
Right before I gave the car to the inspection guy to test, I reset the CEL with a OBDII scanner.
Get my sticker and the CEL comes back! ahah!
Old Apr 19, 2013 | 11:08 AM
krysko8's Avatar
I dont, im gonna look into that. Thanks.
Old Apr 19, 2013 | 11:09 AM
krysko8's Avatar
Thanks for that info. Im gonna look into the spacers.
Old Apr 19, 2013 | 07:31 PM
Slee256's Avatar
Maybe something like this?
http://www.lancershop.com/customer/p...productid=5137
Old Apr 22, 2013 | 05:49 AM
krysko8's Avatar
Originally Posted by Slee256
Thanks alot. I told the dealer about these and they're ordering 2 different ones to see what one works. Ill post some results later this week.
UtahLuge
Lancer Aftermarket Forced Induction Tech
Mar 17, 2014 05:25 PM
jeffgolik1985
Feb 18, 2014 08:27 AM
racerhead2
Jan 29, 2013 10:24 AM
CardShark
Jul 8, 2011 02:23 AM
eric06ix
May 12, 2010 04:54 AM
