HELPPP! ECU Bricked
Old Oct 24, 2020 | 12:28 AM
Archer Odone's Avatar
HELPPP! ECU Bricked
Hi All,
Basically went to read an ecu rom of a 2009 ralliart and it came up with J2534 errors mid way. I turned off the ignition and turned it back on to only have issues. I took the ecu out and followed the steps to reflash the ecu which said successful. Put it back into the car and could not communicate with the ecu like before, fans running at full speed and couldn't start the engine. took ecu out again to flash ecu again and i get this error now, please advise:[18:03:03.549] J2534 API Version: 04.04
[18:03:03.549] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[18:03:03.549] Device Firmware Version: 1.16.4769
[18:03:03.549] Device Serial Number: TAjXIjHn
[18:03:03.550] interface close
[18:03:06.322] opening rom file C:/Users/Archer/Desktop/09 Ralliart tuning/Ming Stock ROM/read_image.srf
[18:03:06.349] 53610012 (175 tables) inheriting evo10base (326 tables)
[18:03:06.353] mitsucan checksum module determined checksum area to be {{0x00000000-0x000fffff}}
[18:03:06.364] using metadata XML ID 53610012 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/53610012 2009 EDM Lancer Ralliart SST.xml
which inherits XML ID evo10base from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo10base.xml
[18:03:06.364] ---notes for evo10base---
2012/10/26 [Tactrix] Updating using multiple base file data sources including base file from Golden Evo repository.
2012/11/01 [Tactrix] Moved most non-address attributes from child files to base class. Standardized file naming. Change scalings on some code modifying tables (i.e. Mode 23 - IFMode 0x05 -> 0x23) to more strongly typed bloblist scalings.
2014/05/20 [Tactrix] Tactrix definition auto cleaned|merged w/ GoldenEvoMay2014.
---notes for 53610012---
2014/05/01 [Tactrix] Original file from Golden Evo repository. If this file is useful to you, please consider donating at http://goldenevo.com/
2014/05/01 [Tactrix] Moved most non-address attributes to evoxbase.xml base class. Standardized file naming.
2014/05/01 [Tactrix] Visually examined tables for obvious errors, but no in-car verification has been done.
2014/05/20 [Tactrix] Removed DTC P0247. Incorrect address.
[18:03:06.402] mitsucan checksum module determined checksum area to be {{0x00000000-0x000fffff}}
[18:03:06.412] using metadata XML ID 53610012 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/53610012 2009 EDM Lancer Ralliart SST.xml
[18:03:06.412] ---notes for evo10base---
[18:03:07.742] J2534 API Version: 04.04
[18:03:07.742] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[18:03:07.742] Device Firmware Version: 1.16.4769
[18:03:07.742] Device Serial Number: TAjXIjHn
[18:03:09.252] sending init sequence 1 (F0F0)
[18:03:12.480] sending init sequence 1 (0001)
[18:03:15.708] sending init sequence 1 (0003)
[18:03:16.412] J2534 error [ERR_TIMEOUT].
[18:03:16.914] J2534 error [ERR_TIMEOUT].
[18:03:17.415] J2534 error [ERR_TIMEOUT].
[18:03:17.415] interface close
Old Nov 9, 2020 | 01:11 PM
RalliFast's Avatar
I forget where we found the instructions but look up how to "bench flash" the ecu, you have to remove it to do so, but it's the only way we were able to unbrick; it's easier than it sounds if you're not too bad at wiring and reading diagrams... Best of luck.
Old Jan 19, 2021 | 09:51 AM
nglett's Avatar
I hope you got your ECU fixed by now. But if you're still looking for benching instructions, I found this (see link below). Was your ECU bricked? Just flashed my car and now I'm getting the same error codes.
https://www.evoxforums.com/threads/h...nch-ecu.29820/
ryzzal
May 5, 2015 09:03 PM
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
REV.olution
Apr 13, 2011 01:43 PM
delkat
15
Jun 27, 2010 09:01 PM
Jim in Tucson
Apr 15, 2010 09:25 PM
