RRM Drop Spring Pics
Old Aug 14, 2009, 03:25 PM
  #31
sith_killer_99's Avatar
The aluminum fuel door is a factory option, some have 'em some don't.
As for rolling the fenders, it all depends on the wheels you get, stock should be fine. Wider will likely require a roll.
Old Aug 14, 2009, 03:35 PM
  #32
GiLizILL's Avatar
^ anything bigger than 225, you will need to be rolled.
Old Aug 15, 2009, 07:43 AM
  #33
xdemoulasx's Avatar
Originally Posted by Piper747
My shop would be myself. I am pretty sure it is done right. Not much to it really. I don't know what I could have done to make it end up lower than it should be. I also had the supervision of a mechanic uncle. I had no issues during the install and it seems to ride just fine. I had to wait three extra weeks for the springs to come in since RRM said they were out of stock and were waiting for a new batch. Maybe this batch is slightly different than the last.
how long did the whole thing take to do? was it hard to do?
Old Aug 15, 2009, 08:02 AM
  #34
Piper747's Avatar
It took about 3 hours. Once the tires are removed it is obvious what needs to be done. The only specialized tool required is a spring compressor (about 20 bucks). An impact is useful but not necessary. Once the strut is out, just compress the spring and remove the 1 nut that secures the end of the strut. Just put it together the way it came apart. Simple.
Old Aug 15, 2009, 09:37 AM
  #35
xdemoulasx's Avatar
cool, thanks. i might try this out. my robispec springs are too stiff for the roads around here, so i might decide to go back to stock.
Old Aug 15, 2009, 10:51 AM
  #36
dfo
dfo's Avatar
Have you seen Smike's post here? https://www.evolutionm.net/forums/7372080-post197.html
Did you do the alignment yourself too?
Old Aug 15, 2009, 12:16 PM
  #37
dmun505's Avatar
dmun505 that looks really slick!
No fender rolling. I don't know it if I will need to once I change the wheels. I really don't want to have to.
thanks man! didnt mean to thread jack, just wanted to show other angles for more reference.
and i did all the work myself guys.
Old Aug 15, 2009, 09:38 PM
  #38
Piper747's Avatar
No no.. I have an appointment early next week to have an alignment done.
Old Aug 16, 2009, 03:50 AM
  #39
08Lancer89's Avatar
How's the ride quality.
Old Aug 16, 2009, 11:15 AM
  #40
Piper747's Avatar
The ride is still decent. I would not want it any rougher for a DD though. Disregarding pot holes and railroad crossings its not much less comfortable that stock. I have noticed a big improvement with cornering. If I didn't have to turn the wheel, I would forget I wasn't going straight!
Old Aug 16, 2009, 12:12 PM
  #41
dfo
dfo's Avatar
Good to hear this improves cornering without worsening ride too much on Canadian roads. I'm looking forward to hearing how it fares through the winter.
Old Aug 16, 2009, 08:20 PM
  #42
08Lancer89's Avatar
Awsome
Old Aug 16, 2009, 09:45 PM
  #43
GiLizILL's Avatar
Originally Posted by piper747
the ride is still decent. I would not want it any rougher for a dd though. Disregarding pot holes and railroad crossings its not much less comfortable that stock. I have noticed a big improvement with cornering. If i didn't have to turn the wheel, i would forget i wasn't going straight!:d
+1
CombatSpeed
Lancer Aftermarket Forced Induction Tech
22
Jun 15, 2015 10:07 AM
romocantu
Lancer Engine Tech
Mar 31, 2014 07:09 PM
yitzac1990
Aug 13, 2010 09:32 AM
Zackdan3
23
Jan 21, 2010 04:27 PM
thebigt
May 12, 2009 08:59 PM
Quick Reply: RRM Drop Spring Pics
