Conical intakes BEWARE! TTP tunes a 2009 Ralliart with fueling problems from intake!
Old Feb 12, 2010, 12:19 AM
  #121
Ralli_Flip_09's Avatar
L.a
Ralli_Flip_09 is offline
Old Feb 28, 2010, 12:37 PM
  #122
mike244's Avatar
So whats the deal then? I called up one of the local shops and they told me that every car is different and that just because that car runs lean doesn't mean mine will, also noted that the downpipe and test pipe would cause these readings to change. So could this be just the one car or would it apply to every car? I ran the UR SRI for a month without any issues and took it off because of this tread. The car runs the same with the stock airbox as it did with the UR SRI, thus making me believe that this issue is related to this particular car. Also why would they sell you a product and say it does not need a tune, would they blatantly want you to ruin your car? I highly doubt it. At this point and time you cannot believe what other people say unless you go and dyno the car and see results for yourself.
mike244 is offline
Old Feb 28, 2010, 02:34 PM
  #123
Taranis's Avatar
It is true that every car will be different. Most should be about the same, but you definitely can not (and should not) completely rely on other people's experience and A/F numbers.
-Taranis
Taranis is offline
Old Feb 28, 2010, 03:28 PM
  #124
secondchace's Avatar
mine had the same issues. The issue is the way the air hits the maf sensor doesnt allow it to recalibrate properly. Its the same issue that cars like the MS3 and Cobalt TC have with intakes and untuned.
secondchace is offline
TTP Engineering
Evo X Dyno Results
Apr 13, 2010 04:23 AM
TTP Engineering
Evo X Dyno Results
19
Mar 15, 2010 05:13 PM
TTP Engineering
Aug 29, 2009 12:26 PM
TTP Engineering
135
Feb 1, 2009 12:07 PM
Quick Reply: Conical intakes BEWARE! TTP tunes a 2009 Ralliart with fueling problems from intake!
