T1R IC Pipe Set on Ralliart
Old Aug 14, 2009 | 02:46 PM
boondoc's Avatar
Originally Posted by dD Spikey
Well, that actually depends if the IC is designed as a direct stock replacement with the same IC pipe fitment as stock, or if the IC requires you to use a different IC pipe set altogether.
But in general, any aftermarket IC for the RA that has stock fitment, or any Evo X IC that has stock Evo X fitment, will work with the T1R pipes.
Alright thanx. That is what i was thinking in my head but still needed to ask.
Old Aug 21, 2009 | 05:25 PM
dD Spikey's Avatar
We have ordered the pieces that are needed to connect the T1R UICP to the stock Ralliart IC inlet. They should be ready in the next week or two. We'll post up when the complete kit is ready to go.
Old Sep 2, 2009 | 12:34 AM
dD Spikey's Avatar
We've confirmed that the T1R IC Pipe set for Evo X will fit Ralliart's with Evo X stock IC.
Here's pics:
As you can see, it's a direct fit to the Evo X stock IC.
Fits perfectly with no modification at all.
So for any of you who are using a stock Evo X intercooler on your Ralliart, the T1R Evo X IC pipes are a direct fit.
Old Sep 2, 2009 | 06:43 AM
Cesarn2928's Avatar
do u require a tune up right after install? or can u just install n run with it witout tune up..?
Old Sep 2, 2009 | 06:47 AM
velocityhead's Avatar
Should not require a tune, but you'll see more power out of it with a tune.
I have a set of red pipes on their way, which will be installed on a RR and EvoX IC. Will have pics soon.
Old Sep 2, 2009 | 11:46 AM
Gibby860's Avatar
The ralliart's stock LCIP fits EVO X's bottom outlet with no issues?
Old Sep 3, 2009 | 12:01 AM
dD Spikey's Avatar
Originally Posted by Gibby860
The Ralliart's stock LCIP fits EVO X's bottom outlet with no issues?
I'd recommend using the Evo X's LICP if you are going to upgrade the IC.
The Ralliart's LICP is plastic and is smaller than the Evo X's LICP. The Ralliart piece also has a bottleneck close to the IC.
There's one more issue though, The Ralliart's LICP touches the Evo X IC's outlet. The two ends push up against each other. It makes fitment a little bit difficult. You can see what I mean in this picture. Once you put on a coupler, it might be a bit harder. It can be done, and it will work, but you'll have to wiggle the fitment and probably push the LICP out a bit.
Old Sep 3, 2009 | 01:16 PM
Gibby860's Avatar
What if u use a silcon 2.5 coupler should work?
Old Oct 18, 2009 | 06:14 AM
joedr's Avatar
EvoM Moderator
Hi!
Can you do the couplers in black as well instead of blue?
That is something that I would be interested.
Also, I have the Evo X IC with the first section (the elbow) from the IC outlet which is in metal.
Questions are:
1. Can I use the Evo X first elbow from the IC and be able to use your kit as well? Can I use stock battery?
2. What else needs to be modified or needed if I decided to use the Evo X elbow and IC?
3. Any upgrades for T-Bolt Clamps?
Just want to make sure I get all that I need!
Old Oct 18, 2009 | 08:06 AM
I think I can answer these for you, as I've asked the same and upgraded using the same parts.
The only color coupler I was able to get with the kit was blue.
1 - yes
2 - only thing that needs modifying if you use the EvoX stock lower pipe is the pipe running to the BPV
3 - not sure but any aftermarket clamps of the right size will work
https://www.evolutionm.net/forums/09...tercooler.html
I have a thread documenting my experience with it.
velocityhead
246
Jun 1, 2018 02:22 PM
keshav707
Nov 19, 2016 09:30 AM
hybrid_r
EvoX 'For Sale' Suspension / Brakes / Handling
Jan 14, 2009 04:15 PM
dD Spikey
58
Aug 14, 2008 03:30 PM
EVOlutionary
Apr 13, 2007 08:39 PM
