Help with test pipe install
Old Jan 18, 2010 | 01:50 PM
Jcusco407's Avatar
I bought a used ams testpipe on here without the gaskets or bolts. Im buying the gaskets at kamispeed which is 10 minutes away and i was gonna order the bolts from ams but shipping is $15 dollars for something that costs 4. Is there anything special about the bolts necessary to put on the testpipe? can i use the stock ones? thanks
Old Jan 18, 2010 | 01:56 PM
tre's Avatar
tre
i'd imagine you could use the stockers provided they came off in one piece. since its a newer car you shouldn't have a problem. I know from taking off exhaust bolts on older vehicles you always end up busting them off.
if you bust them just go to your local hardware store and look for similar sized stainless nuts and bolts. and be sure to get lock washers just to be safe.
Old Jan 18, 2010 | 02:55 PM
Jcusco407's Avatar
thanks thats what i thought but wasnt sure since the new pipe comes with bolts
Old Jan 20, 2010 | 07:00 PM
RotorGlow's Avatar
The old bolts are perfectly fine as long as the threads are in good shape. Otherwise just reuse the stock ones. They aren't even special hi-temp bolts. Just cheapies.
Old Jan 20, 2010 | 07:11 PM
Jcusco407's Avatar
Im doing the install this weekend. do you think its worth it to change them out for high temp ones?
Old Jan 21, 2010 | 06:33 AM
velocityhead's Avatar
If you're worried about them freezing up next time you need to remove the exhaust, put a little dab of anti-seize on the threads first.
Old Jan 21, 2010 | 06:48 PM
RotorGlow's Avatar
I would just use whatever you have on hand. I just so happens that my CP-E testpipe came with new bolts, nuts and gaskets.
+1 for CP-E
EVOSWAG
Sep 30, 2015 05:05 AM
SamTrippyMan
Aug 17, 2015 10:52 AM
phyzfer
Evo X How Tos / Installations
Dec 9, 2013 04:12 AM
ohthree
Sep 10, 2006 11:03 PM
PANGES
Jun 13, 2006 12:33 PM
