UR Testpipe problem.
Old Sep 10, 2006 | 10:12 PM
ohthree's Avatar
I bought a UR testpipe and I have a AMS catback, they both have bungs for o2 sensors, should i close one of them before i install it, am i able to use a wideband in that space later on? thanks you for your help.
Old Sep 10, 2006 | 10:15 PM
EiEVO's Avatar
what you need is a O2 bung plug... Go to your local automotive shop or store... AND yes you need to close off the one you dont use.. Otherwise you WB readings will not be correct.
Old Sep 10, 2006 | 10:17 PM
ohthree's Avatar
thanks, awesome i never thought of that
Old Sep 10, 2006 | 10:27 PM
mitsuorder's Avatar
Keep in mind that you wouldn't want to use the o2 bung in the UR pipe to get your wideband readings since it pulls the sensor out of the direct path of the gases.
Old Sep 10, 2006 | 10:42 PM
fromWRXtoEVO's Avatar
Sorry to reply too late but I have had the same issues on previous cars. Definately a very easy fix, normally the 02 bung matches the oil plugs on many other cars and you can find them in any hardware store or automotive store.
Again, I apologize for double answering I just want to clarify that this is indeed a easy and cheap fix, that is all.
Carlos
Old Sep 10, 2006 | 10:54 PM
ohthree's Avatar
i know, im going to put the wideband in my ams catback bung and put the the one on the UR testpipe for the o2
Old Sep 10, 2006 | 11:03 PM
jhanksevo's Avatar
yes definetly put the 02 in the testpipe. i also notice i never got a cel too
kt411gcn
Mar 24, 2012 09:12 PM
Jookies
Apr 9, 2011 07:48 PM
mufasis
15
Mar 8, 2010 11:19 PM
Clipse3GT
Jul 2, 2009 07:12 PM
sonicrx
14
Apr 14, 2009 01:28 PM
